BWV
- 1,603
- 1,956
Other than a brine, which will penetrate and tenderize meat, marinating does nothing:
https://www.splendidtable.org/story...s-test-kitchen-marinating-basting-and-boiling
Article also says basting Turkeys is pointless
FL: Wait, what?DW: This is the best thing – when we're not believed – because, of course, we back everything up with science. Years ago, we started feeling like marinating doesn't seem do much, particularly when you're doing chicken or meat – which are the things people marinate most often. We decided to do an experiment. We took boneless skinless chicken breasts in four different marinades: soy, yogurt, red wine, and lemon and garlic. We left them in there for 18 hours. After that time, the marinade had penetrated less than between 1-3 millimeters, which is less than a tenth of an inch, and that's after 18 hours. We took the chicken breasts, shaved off the amount the marinade had gone in – the outer three milliliters – and roasted them along with other chicken breasts that had not been marinated. We had people taste them. No one could taste any difference at all.
FL: That’s a long time.DW: It was a blind tasting with a large panel of 30 testers. The only way you could taste any difference was if you tasted one that had not had that little tiny bit shaved off. Even then there was only a faint difference. Again, this was after 18 hours in marinade.
DW: It's a long time; and no one wants to marinate anything that long. All marinating does is put a tiny bit of flavor on the outside part of whatever it is you're marinating. The other thing people say is that marinating tenderizes things. If you use acid – or the other thing people often use is papaya juice – theoretically, it will tenderize the meat, but only to the same depth as those marinades penetrated. All it does is make the outside mushy. No matter how long you marinate, you're only going to get mushy exterior and a tiny bit of flavor on the outside. It’s much better to skip marinating. Instead, cook the food and then put the flavor on it afterwards.
