Markov property: compatible with momentum?
In summary, the conversation discusses whether a system of two interacting atoms can have the Markov property, which means that the future positions of the atoms depend only on their current position and not the past. The speaker is unsure due to the atoms' momentums, which are a property of the present state but depend on past states. The other person clarifies that the Markov property is dependent on the variables chosen to define the state, and these may differ depending on whether actual atoms or point particles are considered. The conversation also raises the question of whether other variables like mass, velocity, and acceleration should be included in the definition of state.
lolcopters
Say I'm simulating the movements of two interacting atoms. Could this system have the markov property (the future positions of the atoms depend only on the current position, not the past)?
What's got me on the fence are the atoms' momentums: it's a property of the present state (at time t, the momentum is p), but its value depends on past states. So does anyone know if a system like this could have the markov property?
Thanks
You misunderstood what Markov is about. Of course, the state of any system at time t0 depends on what happened at times t < t0. But in a Markovian process, there is no memory of how the state at time t0 was reached. All that is important is that the state at time t0 completely describes the system (and its future evolution).
In the case of two atoms governed by a known Hamiltonian, given the wave function ψ(t0) of the two-atom system, one can calculate ψ(t) for any t > t0. No need to know the wave function for any time < t0.
Likes lolcopters
It isn't meaningful to ask whether a physical system has the markov property until you say what variables you will choose to define a "state". A physical system may have the markov property when one definition of "state" is used and not have it when a different definition is used.
Are you considering actual atoms - or just thinking about "point particles" ?
You only mention "position" as the variables involved in your definition "state" ? Did you intend to omit variables like mass, velocity and acceleration ?
Likes DrewD
FAQ: Markov property: compatible with momentum?
1. What is the Markov property and how is it related to momentum?
The Markov property is a mathematical concept that describes the probabilistic behavior of a system. It states that the future state of a system is only dependent on its current state, and is independent of its past states. This property is compatible with momentum because momentum is also a property that is only dependent on the current state of a system.
2. Can the Markov property be applied to all systems?
No, the Markov property is not applicable to all systems. It is only applicable to systems that exhibit the characteristics of being memoryless and having a finite state space. These conditions must be met for the Markov property to hold.
3. How is the Markov property used in scientific research?
The Markov property is used in various scientific fields, such as physics, biology, and economics, to model and analyze complex systems. It allows researchers to make probabilistic predictions about the future behavior of a system based on its current state, without having to consider its entire history.
4. What are some limitations of the Markov property?
One limitation of the Markov property is that it assumes that the future state of a system is only dependent on its current state. In reality, there may be certain external factors or events that can influence the system's future behavior. Additionally, the Markov property is not applicable to systems with an infinite state space.
5. How does the Markov property differ from other mathematical concepts?
The Markov property is unique in that it only considers the current state of a system, whereas other mathematical concepts, such as differential equations, take into account the system's past behavior. This makes the Markov property particularly useful for modeling and analyzing systems that exhibit random or unpredictable behavior.
