Martian atmosphere weight and gas constant
In summary, the mean molecular weight of the Martian atmosphere is 42.704 g/mol, and the gas constant for 1kg of such an atmosphere is 0.023417. Using this value and the surface temperature of Mars as 0° C, the surface pressure is calculated to be 273.14988. However, there may be discrepancies with this calculation as there are different definitions and units used for the gas constant in different fields.
jg24
Determine the mean molecular weight of the Martian atmosphere which is composed of 95% carbon dioxide, 3% nitrogen, 1.6% argon. What is the gas constant for 1kg of such an atmosphere?
Using the value for R from the last problem assuming the surface temperature of Mars is 0° C and has a cubic meter of gas weighs 4.6kg what is the surface pressure?
CO2 = 44 g/mol at 95% = 41.8 g/mol
n2 = 28 g/mol at 3% = 0.84 g/mol
Ar = 40 g/mol at 1.6% = .064 g/mol
Martian atmos molecular weight = 42.704
Gas constant = 1/mean molecular weight?
Gas constant using above formula 0.023417
Surface pressure = pv=mRT
P=(mRT)/V
P=((42.704)(0.023417)(273.15))/1
P=273.14988
Is this even close to right?
I've never heard of anyone calculating the gas constant. Its value is independent of composition. Were you taught that the gas constant was inversely proportional to the mean molecular weight of the gas in question?
That's what I have in my notes.
OK. So I've just learned that there is a universal or "ideal" gas constant and an individual gas constant. I've only ever heard of the ideal gas constant. They are related as:
Ru = R * Mgas
Where
Ru is ideal gas constant
R is individual gas constant or gas mix constant
Mgas is molecular weight of gas or gas mix.
source
So, what units did you use for Mgas?
SI units for the gas constant are J/Kg K. I'm thinking that the gas constant value for a gas mix that is 95% CO2 should be close to the gas constant of CO2 which is ~189 J/Kg K. Yours is ~0.02.
To get my constant I just did 1/42.704 grams which was the 3 gas %'s added up. I may be doing it completely wrong.
They use even more strange definitions in climate sciences. I have browsed "Principles of Planetary Climate" once, and on some pages every second concept they introduced used known name, but a twisted definition, or normal definition, but a twisted name. Why do they call molar fraction molar concentration?
If you look at the definition chemisttree posted, it can't be 1/something. Solve the formula he posted for the R.
Related to Martian atmosphere weight and gas constant
1. What is the weight of the Martian atmosphere?
The average weight of the Martian atmosphere is about 1% of Earth's atmosphere. This is equivalent to about 0.01 times the weight of Earth's atmosphere, or 0.0067 times the weight of Earth's oceans.
2. How does the weight of the Martian atmosphere compare to Earth's atmosphere?
As mentioned, the weight of the Martian atmosphere is significantly less than Earth's atmosphere. This is due to the fact that Mars has a much lower gravitational pull, as well as a thinner atmosphere overall.
3. What is the gas constant for the Martian atmosphere?
The gas constant for the Martian atmosphere is 0.0821 L atm/mol K. This is slightly lower than Earth's gas constant, which is 0.0821 L atm/mol K.
4. What gases make up the Martian atmosphere?
The primary gases that make up the Martian atmosphere are carbon dioxide (95%), nitrogen (2.7%), and argon (1.6%). There are also trace amounts of oxygen, methane, and other gases.
5. How does the temperature affect the weight of the Martian atmosphere?
As with any gas, the weight of the Martian atmosphere is affected by temperature. When the temperature increases, the molecules in the atmosphere move faster and the weight of the atmosphere increases. When the temperature decreases, the weight of the atmosphere decreases.
12K
18K
