MHB Mason's question via Facebook about solving a system of equations (2)
The system of equations provided is solved by eliminating the variable z from the second and third equations, leading to a simplified system. After manipulating the equations, it is determined that x equals 1. Substituting x back into the equations allows for the calculation of y, which is found to be -2. Finally, z is calculated as 3, resulting in the solution (x, y, z) = (1, -2, 3). The consistency of the equations is confirmed as they all yield the same values for z.
Prove It
MHB
Solve the following system for $\displaystyle \begin{align*} x, y, z \end{align*}$:
$\displaystyle \begin{align*} z &= 12 - x + 4\,y \\ z &= 4 + 5\,x + 3\,y \\ z &= 5 - 12\,x - 5\,y \end{align*}$
As all the z coefficients are the same, it's a good idea to eliminate the z values in the second and third equations, so apply R2 - R1 to R2 and R3 - R1 to R3...
$\displaystyle \begin{align*} z &= 12 - x + 4\,y \\ 0 &= -8 + 6\,x - y \\ 0 &= -7 - 11\,x - 9\,y \end{align*}$
Now we can multiply the second equation by 9 in order to eliminate the y terms...
$\displaystyle \begin{align*} z &= 12 - x + 4\,y \\ 0 &= -72 + 54\,x - 9\,y \\ 0 &= -7 - 11\,x - 9\,y \end{align*}$
Now apply R3 - R2 to R3
$\displaystyle \begin{align*} z &= 12 - x + 4\,y \\ 0 &= -72 + 54\,x - 9\,y \\ 0 &= 65 - 65\,x \end{align*}$
Thus $\displaystyle \begin{align*} 65\,x = 65 \implies x = 1 \end{align*}$, giving
$\displaystyle \begin{align*} 54 \, \left( 1 \right) - 9\,y &= 72 \\ -9\,y &= 18 \\ y &= -2 \end{align*}$
and
$\displaystyle \begin{align*} z &= 12 - 1 + 4\,\left( -2 \right) \\ z &= 3 \end{align*}$
Thus the solution is $\displaystyle \begin{align*} \left( x , y, z \right) = \left( 1, -2, 3 \right) \end{align*}$.
Mathematics news on Phys.org
Equivalently, since z is equal to each of 12−x+4y, −8+6x−y, and −7−11x−9y, they are all equal to each other:
12- x+ 4y= -8+ 6x- y and
-8+ 6x- y= -7- 11x- 9y.
From there, do the same as Prove It.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
11K
11K
11K
10K
10K
11K
10K
