Mass and energy analysis of control Volumes (thermodynamics)
In summary, the conversation discusses three different problems related to thermodynamics and fluid dynamics. The first problem involves a cylinder containing water that is cooled at a constant temperature until it reaches a specific volume, followed by a constant volume process that ends with a specific pressure. The second problem involves a cubic meter of water at a high pressure and temperature being cooled and the final pressure and heat transfer are determined using both real and ideal gas concepts. The third problem involves a system with a kilogram of saturated steam being heated and work being performed by an electric current. The conversation also mentions the use of steam tables in solving these problems.
RevanKnight
1) A cylinder with an initial volume of 1.5 m3 initially contains water 1 MPa and 200 ° C (condition 1). Container is cooled at constant temperature until the volume is 42% of the initial volume (state 2). The constant temperature process is followed by a constant volume process that ends with a cylinder pressure of 40 bar (state 3). a) Determine the pressure, in bars, and the enthalpy, in kJ / kg, in state 2. b) Determine the temperature in ° Celsius, and the enthalpy at state 3. c) Draw the two processes in a P-v diagram.
2. A cubic meter of water at 10.0 MPa and 400 ° C is found inside a rigid tank. The fluid is cooled until its temperature reaches 320 ° C. Determine the final pressure in bars, and heat transfer in kilojoules if the fluid is a) a real gas and b) an ideal gas, in both cases using tabulated data. c) Calculate the percentage of error made in determining the heat transfer when using the ideal gas model.
3. One kilogram of saturated steam at 0.6 MPa dried in a cylinder with piston. The system receives 250 kJ of heat, and performs certain amount of work to electric current circulating 1.6 ampere through a resistor in the fluid for an hour and a half (1.5 h). If the final temperature of water is 500 ° C and the process is at constant pressure. Draw the complete system and enter the addresses (work and heat). Determine: a) The required voltage, in volts, giving the current stack. Neglect the energy stored in the resistor, b) piston work c) The electrical work. 2. The attempt at a solution
about first problem : How I can calculate the final pressure of the fluid and this water vapor is not an ideal gas?
about second problem: problem talk about real gas concept and ideal gas concept , I'm really confused and do not know how start.
about third:I know I have to start with the final data, finding the values ​​of enthalpy and specific volume. And I have to finish writing the energy balance equation. The system does not seem to affect the potential or kinetic energy. I need help to solve it.
Hi RevanKnight. Welcome to Physics Forums.
In your thermo course, have they covered how to used the steam tables yet? Without being able to use the steam tables, these are much more complicated problems.
Chet
Related to Mass and energy analysis of control Volumes (thermodynamics)
1. What is the concept of a control volume in thermodynamics?
A control volume is a defined region in space where the mass and energy of a thermodynamic system are analyzed. It can be any shape or size, and is often used to simplify complex systems by focusing on a specific area of interest.
2. How is mass flow rate calculated in a control volume analysis?
The mass flow rate in a control volume is calculated by multiplying the density of the fluid by the velocity of the fluid and the cross-sectional area through which it is flowing. This equation is known as the continuity equation and is a fundamental principle in thermodynamics.
3. What is the first law of thermodynamics and how does it relate to control volume analysis?
The first law of thermodynamics states that energy cannot be created or destroyed, only transferred or converted. In control volume analysis, this law is used to track the energy entering and leaving the control volume, and how it is being converted or transferred within the system.
4. How is the energy balance equation used in control volume analysis?
The energy balance equation, also known as the first law of thermodynamics, is used in control volume analysis to determine the net change in energy within the control volume. This equation takes into account the energy entering and leaving the control volume, as well as any energy that is generated or consumed within the system.
5. Can control volume analysis be used in both closed and open systems?
Yes, control volume analysis can be used in both closed and open systems. In a closed system, no mass enters or leaves the control volume, while in an open system, mass can enter or leave the control volume. Control volume analysis is a versatile tool that can be applied to a wide range of thermodynamic systems.
10K
31K
