Mass/Density problem - please check my working.
  • Thread starter bentleyq
In summary: The summary should read:In summary, the Olympic pool has a volume of 2500m^3 and a mass of 2.5e6kg when filled with water. It would take approximately 312500 minutes (217 days) to fill the pool from a standard garden hose with an average flow rate of 8 liters per minute.
bentleyq
1. An olympic pool is 50m long 25m wide and a minimum average depth of 2m
a) If the pool is filled as specified, what is the mass of water? Denisty of water to be 1.0g/cm^3
b) How long will it take to fill the pool from a standard garden hose, if the flow rate from hose has average of 8 liters per minute?
2. Homework Equations (density = mass/volume)(volume = LxWxH)
3. a) Volume = 25 x 50 x 2 = 2500m^3
Convert density to kg/m^3, 1g/cm^3 = 1000kg/m^3
mass = 2500 x 1000 = 2.5e5kg
b) I just did m^3 into liters, so 2500m^3 = 2.5e5liters
2.5e5/8
=312500min approx 217 days
I know its basic question, with unit conversation etc, but I have no answers to check my working. Thanks
Welcome to PF bentleyq!
2.5e5/8
Check your arithmetic. 2500 * 1000 = 2.5e6. You're too low by a factor of 10.
Your conversion to litres is also similarly wrong.
Ah thanks, i should be 2.5e6liters also, but seems i still have the correct time of 312500min?
Looks okay to me! EDIT: your answer for the time, I mean.
Your calculations for the mass of water in the Olympic pool are correct. The density of water is commonly known to be 1.0g/cm^3, but it is important to remember to convert to the appropriate units for consistency. Great job on that!
For part b, your approach is correct. However, your final answer of 217 days seems very long. This could be due to an error in unit conversion or calculation. Double check your numbers and make sure you are using the correct units. Also, make sure you are converting from minutes to hours or days for the final answer. It should not take that long to fill an Olympic pool with a standard garden hose.
Overall, your working is good and it is important to double check your calculations and units to ensure accuracy in your results. Keep up the good work!
Related to Mass/Density problem - please check my working.
1. What is the difference between mass and density?
Mass is the measure of the amount of matter in an object, while density is the measure of how tightly packed the matter is in an object.
2. How do I calculate mass?
Mass can be calculated by multiplying an object's volume by its density.
3. What is the formula for density?
The formula for density is: density = mass / volume
4. How do I know if my density calculation is correct?
You can check your density calculation by comparing it to the known density of the material you are measuring. If they are similar, then your calculation is likely correct.
5. Can an object have a negative density?
No, an object cannot have a negative density. Density is a measure of how tightly packed the matter is in an object, and it cannot be negative. However, an object can have a negative mass, which would result in a negative density calculation.
