Mass falling and pulling others on a rough surface
In summary: That's simple:$$T=(g-a)m=...=\frac{3+3\mu}{4}mg$$In summary, the question asks you to find ##T##. You find it by adding the equations: ##mg-T=ma## and ##T-3mg\mu=3ma##.
Karol
1,380
4 m masses, μ is the coefficient of friction. what is the tension and what should the maximum μ be to allow acceleration.
Mass-acceleration: F=ma
$$\left\{\begin{array}{l} mg-T=ma \\ T-3mg\mu=3ma \end{array}\right.~~\rightarrow~~a=\frac{1-\mu}{4}g$$
So, from here, μ≤1 in order for a to be positive. but logically:
$$3mg\mu\leq mg~~\rightarrow~~\mu\leq \frac{1}{3}$$
Check your working for solving simultaneous equations.
You're mixing up static & dynamic friction coefficients. Your "logically" expression is correct if μ = μs.
I add the equations:
$$+\left\{\begin{array}{l} mg-T=ma \\ T-3mg\mu=3ma \end{array}\right.$$
$$mg-3mg\mu=4ma~~\rightarrow~~a=\frac{1-\mu}{4}g$$
The question didn't distinct between the coefficients, it mentions only one.
I believe that should give you a = g(1 - 3μ)/4
Then you need to ensure that a is positive, g and 1/4 are positive constants so you have the restriction that: 1-3μ ≥ 0
$$\left\{\begin{array}{l} mg-T=ma \\ T-3mg\mu=3ma \end{array}\right.~~\rightarrow~~a=\frac{1-3\mu}{4}g$$
Thanks HoodedFreak
Thanks HoodedFreak
The first part of the question asks you to find ##T##. I assume this means ##T## in terms of ##m, g## and ##\mu##. But, you've eliminated ##T## from your equations.
PeroK said:
The first part of the question asks you to find ##T##. I assume this means ##T## in terms of m,gm,gm, g and μμ\mu. But, you've eliminated ##T## from your equations.
That's simple:
Likes PeroK
Related to Mass falling and pulling others on a rough surface
What is mass falling and pulling others on a rough surface?
Mass falling and pulling others on a rough surface refers to the movement of objects with mass on a surface that has friction or resistance. This can occur when an object with mass (such as a ball) is dropped or when a larger object (such as a person) pulls or drags smaller objects on a rough surface.
What factors affect the speed at which mass falls on a rough surface?
The speed at which mass falls on a rough surface is affected by several factors, including the mass of the object, the angle at which it is dropped or pulled, the surface area of the object, and the amount of friction or resistance on the surface.
How does friction impact mass falling and pulling others on a rough surface?
Friction plays a key role in mass falling and pulling others on a rough surface. Friction is the force that opposes motion, and on a rough surface, it can slow down the movement of objects with mass. This can affect the speed and distance that an object falls or is pulled.
What is the difference between mass falling on a smooth surface versus a rough surface?
The main difference between mass falling on a smooth surface versus a rough surface is the presence of friction. On a smooth surface, there is less friction, so objects with mass can fall or be pulled at a faster speed and for a longer distance. On a rough surface, the friction creates resistance, which can slow down the movement of objects with mass.
How is the force of gravity involved in mass falling and pulling others on a rough surface?
The force of gravity is a key factor in mass falling and pulling others on a rough surface. Gravity is the force that pulls objects towards the center of the Earth, and it is what causes objects with mass to fall towards the ground. The force of gravity also affects the weight of objects, which can impact their ability to pull or drag other objects on a rough surface.
