BabyHuey06
- 9
Let's say I am plowing snow in a straight line using a standard V-plow. The angle of the V between both blades is 130 degrees. The coefficient of kinetic friction between the blades and the snow is about .1. The speed of the plow is 5 mph or 2.2 meters per second. The cross-sectional area of the front of the plow is 2 meters wide by .5 meters tall. The plow itself has a cross sectional geometry of a semi circle with a radius of .25 meter.
The density of the snow is 300 kg/m^3. The cross-sectional area of the swath of snow is 2 meters wide by .25 meters tall.
What will be the mass flow of snow both into and out of the plow?
Because the plow is moving at such a slow speed. Assume that the snow accumulates to fill the snow plow before any snow leaves the plow.
mass flow = density x velocity x cross-sectional area
All other physics equations for kinematics
The mass flow into the plow = (300 kg/m^3) x (2.2 m/s) x (2m x .25m) = 330 kg/s
The mass flow out of the plow = ? I don't know how to find it
