Mass flow rate of cooling water in Diffuser
In summary: The components of the flue gas are SO2, H2O, CO2, and O2. The percentages of each gas are not known, but they are probably in an unspecified proportion.
Max_sky
Hello Everyone,
I am Mayur
I am working on a system, in the system there is one diffuser through which exhaust gases at 3000K are flowing at a rate of 170Kg/s. The material of diffuser is Stainless Steel. The diffuser is double walled type with cooling water flowing between the walls.
I need to find the mass flow rate of cooling water to keep the system cool.
Can anyone give me the formula or some methood to calculate the mass flow rate..
Thanx
Hello,
What you have is a double shell heat exchanger (or double shell radiant recuperator) with flue gas inlet temperature of 3000 K (2540 F). That is extremely hot.
More information is needed to begin any type of calculation.
1. What is the pressure of the cooling water and the flue gas?
2. What is the inlet temperature of the cooling water?
3. What is the maximum allowable exit temperature of the cooling water?
4. Is the cooling water allowed to change phase to steam?
5. What is the outlet temperature of the flue gas? If you don't know this value then knowing the inlet and outlet temperature of the cooling water will be sufficient.
6. What is the flue gas stream compose of? CO, CO2, H20, ... I am sure it is a combination of them, so what are the percentages (volume or weight % of each component?)
7. What is the Specific Heat of constant pressure, Cp, of the flue gas?
Thanks
Matt
Thanx Matt
The pressure of the Exhaust gas in 4 bar max, the shell thickness is 36mm, flow of the exhaust gas is for not more than 200Sec, we have to decide the inlet an outlet temperature of the cooling water.
the purpose of cooling is to protect the shell from heat and not to cool the exhaust.
About the exhaust gas it's a misture of SO2, H2O, CO CO2,...etc in very indefinite proportion.
I could not figure out the Cp for the gas.
Let me no if the data is sufficient...
Thanx
Hi Max,
You will need to know the Cp value for the gas stream. See the TEMA (Tubular Exchange Manufacturers Association) standards. In there is a method of how to obtain this value.
Thanks
Matt
Hey Matt
The Cp value for the exhaust gas is approx 1.318 KJ/Kg/K. this value may change, so if you can give me some general formula in terms of cp it will be better for me.
Thanx
Max
... so if you can give me some general formula in terms of cp ...
My company uses a proprietary method of calculating the Cp values for gas mixtures, but I checked it against the method in the TEMA standards and the results are in close agreement for the mixtures that I checked. So if you follow the method in the TEMA standards you should be able to calculate an accurate Cp value. Do you have access to the TEMA standards?
Thanks
Matt
No i don't have access to TEMA Standards. Is there any other way i can to get the Cp value...??
Thanx
Max
I can calculate it for you. What are the components of the flue gas and each of their volume percents?
Thanks
Matt
Related to Mass flow rate of cooling water in Diffuser
1. What is the definition of mass flow rate of cooling water in a Diffuser?
The mass flow rate of cooling water in a Diffuser refers to the amount of water that is flowing through the Diffuser at a specific time. It is measured in kilograms per second (kg/s) and is an important parameter in determining the efficiency of the cooling system.
2. How is the mass flow rate of cooling water in a Diffuser calculated?
The mass flow rate of cooling water in a Diffuser is calculated by dividing the total mass of water flowing through the Diffuser by the time it takes to flow through. This can be calculated by using a flow meter or by measuring the volume of water and converting it to mass using the density of water.
3. Why is the mass flow rate of cooling water in a Diffuser important?
The mass flow rate of cooling water in a Diffuser is important because it directly affects the efficiency of the cooling system. If the flow rate is too low, the cooling may not be effective and if it is too high, it can cause unnecessary energy consumption. It also helps in determining the amount of water needed for the cooling process.
4. How does the design of the Diffuser affect the mass flow rate of cooling water?
The design of the Diffuser can have a significant impact on the mass flow rate of cooling water. A well-designed Diffuser will have a smooth and streamlined shape, which will minimize friction and turbulence, allowing for a higher flow rate. On the other hand, a poorly designed Diffuser can create obstacles and cause a decrease in flow rate.
5. Can the mass flow rate of cooling water in a Diffuser be adjusted?
Yes, the mass flow rate of cooling water in a Diffuser can be adjusted by controlling the water flow using valves or pumps. This can help in maintaining the desired flow rate for optimal cooling and can also be used to regulate the amount of water used in the cooling process, making it more efficient.
  • Mechanical Engineering
