OUmecheng
- 18
The Mass Flow Rate in a water flow system determined by collecting the discharge over a timed interval is 0.2 kg/s. The scales used can be read to the nearest 0.05kg and stop watch is accurate to 0.2 s. Estimate the precision with which the flow rate can be calculated for time intervals of a.) 10s and b.) 60s
Mdot= mass flow rate
Ok so I found the change in mass by using the flow-rate and given time: m = (Mdot)(change in time) so m = (0.2kg/s)(10s) = 2kg
Then i found the uncertainty in the time and mass:
Ut = 0.2s/10s = 0.02s
Um= 0.05kg/2kg
Then I took uncertainty of the mass flow rate, which came from a bunch of partials like this (d is delta):
UMdot = +/- {[(m/Mdot)(dMdot/delta m)(Um)^2 + (t/Mdot)(dMdot/dt)(Ut)^2]}^(1/2)
Then
UMdot = +/- {[((1)( +/- 0.025)^2 + ((-1)(0.02)^2]}^1/2
=0.032 = 3.2%
BUT the answer is exactly half of that, 1.6%
Where the hell did I go wrong?
I can figure out b.) no problem once I figure out why the initial problem isn't working.
Um= 0.05kg/2kg
Then
=0.032 = 3.2%
