Mass is independent of tendency to break static friction?
In summary, the conversation discusses the relationship between mass and static friction. The speaker explains that as mass increases, so does the normal force and the force of static friction. However, in the formula for centripetal acceleration, the mass seems to cancel out, leading to confusion about the role of mass in frictional force. The expert then clarifies that the acceleration due to friction is a constant μg, similar to the constant acceleration due to gravity. The net acceleration of an object is determined by the difference between the applied force and the frictional force, and the net force is equal to the mass multiplied by the difference between μg and the applied acceleration. The conversation concludes with an analogy to tossing a ball in the air, where gravity is
Ocata
198
Hello,
I'm trying to reconcile what seems to me to be a contradiction.
Last week, I did a lab experiment where we stacked some metal bars in a tray and measured the force required to pull the tray into motion and break away from the force of static friction. As we predicted, the more mass we placed in the tray, the more force was required to move the tray. So clearly, to me, as you increase the mass, you increase the weight, thus you increase the normal force, and so force of static friction increases since Fn(mue) = Force of Friction, which means the force required to pull the tray to overcome Fn increases as mass increases. I hope this is correct (or else I'll have to redo my lab report).
However, now that I'm learning about centripetal acceleration I'm going back to the linear static friction lesson from last week and wondering why the formula seems to lead to the masses cancelling out:
[itex][F_{net} = ma] = [F_{friction} = ma] = [μ(F_{N}) = ma] = [μ(F_{G}) = ma] = [μ(mg) = ma]
[μ(g) = a][/itex]
In our lab, we used one surface type. So μ remained constant. We calculated the weight of the cart using the same constant for gravity, 9.8m/s^2.
I definitely felt that has we added weight to the cart, I had to pull with more and more force to break the cart into motion. So why now that I'm learning about centripetal force am I learning that m actually cancels out of the equation?
If mass definitely has an effect on the frictional force, then why does it cancel out of the equation and why is said not to be a factor?
It takes more force to overcome the static friction of a heavier mass. It also takes more force to cause the acceleration of a heavier mass. So static friction and acceleration stay in the same proportions regardless of mass.
Likes Ocata
If friction is the only force acting on the object, it will generate a fixed acceleration of μg. However, to generate that acceleration, the heavier an object, the more frictional force would be required.
Think of it like gravity. Gravitational force is more on heavier objects and is denoted by mg. However, the gravitational acceleration is constant regardless of object's mass. In the same way, the frictional force would be μmg, but the accleration is a constant μg.
Likes Ocata
Okay so μg is constant regardless of the object's mass. Does that mean that when the object breaks free of static friction it will be accelerating at a rate of μg? That is, in order to slide, does the object need a net acceleration of μg?
Or will the net acceleration on the object be a different rate than μg?
For instance in an elevator at rest, gravity is pulling on you with an acceleration of 10 but you are not actually moving at 10. In fact you are not accelerating at all. If the Force of Gravity were a bit stronger than the opposing force holding the elevator stationary, then the elevator would accelerate downwards. For instance If the force downward were Fg= mg= 500kg(10) = 5000N. And the force upward was F= ma = 500(11) = 5500N. Then the net acceleration would be 11-10= 1m/s^2 upward. The "applied accelerations are 10m/s^2 and 11m/s^2, but you are actually traveling at an acceleration of 1m/s^2.
So for friction, it seems you are saying that μg is like the acceleration downward even though the object is not actually accelerating at all. Then when there's a force applied that is greater than and in the opposite direction to the force of friction, then a net acceleration will occur.
For instance, if μ =2, then the force of friction is mμg=m(a). So if there is an imbalance such that mμg<ma then Fnet= mμg -ma = 10kg(2)(10) - 10kg(21m/s^2) = 10kg(21-20)
So the actual acceleration of the object is only 1m/s^2 even though forces with much larger accelerations, 20 and 21, are acting upon it.
Then that means that in the equation μg=a, a does not represent the actual (net) acceleration of the body. But the acceleration applied in the direction opposite the frictional force. The net acceleration would be μg - a = a_net, and the net force on the object would be Fnet = m(μg-a). Yes?
The F in F=ma is always the net force. Thus, you don't even start thinking terms of accelerations until after you've identified and added all the individual forces together to determine the net force.
Likes Ocata
I think you're confusing static and kinetic friction. Initially if the object is at rest on a flat surface it is in equilibrium with no net force. As begin to apply a force on the object static friction opposes your applied force until you reach the maximum static friction possible. The maximum static friction possible is μmg. Then when you apply a force greater than that maximum the object is set in motion with an acceleration of (Fapplied -μmg)/ m. As soon as I let go of the object, the only net force acting on it will be kinetic friction. It is this force that produces the acceleration μg which is the same regardless of mass. That is the rate at which the object will slow down.This is analogous to the example of tossing a ball up in the air. Once tossed, the only net force acting on the ball is gravity and it produces an acceleration, g, which is the same regardless of mass.
Likes Ocata
I have 2 situations.
Situation 1) I'm given a known mass and I measure the force required to set the object in motion. And then I calculate μ.
For example, I start with a 1kg mass. Max static friction is measured with a force meter to be, say, 5N. Normal force is 1kg(10m/s^2) = 10N. fs = μ(FN), so μ = 5N/10N = .5.
If I wanted to know the acceleration, I would have to realize that any motion will depend on the coefficient of kinetic friction , as umath1 advised. So if the coefficient of kinetic friction was μ=.2 , then the net force on the object would be 5N - μ(FN) = 5N - .2(10N) = 5N - 2N = 3N.
So acceleration would be f/m = 3N/10m/s^2 = .3m/s^2
If the coefficient if kinetic friction happened to be μ= 0, then
acceleration would be (5N - μ(FN))/m = (5N - 0N)/1kg = 5m/s^2
Situation 2). I am given a mass and coefficient of friction ( I believe it must be static friction).
Lets say the mass is 1000kg and μ = .5. If I want to find the maximum acceleration without skidding, I can look at the situation in two ways.
A). I can look at the mass as a car on wheels where the vehicle will travel at the indicated acceleration since the tires are not experiencing friction even though the car is in motion.
Or
B) I can look at the mass as a block, in which any movement will be a sliding motion that has overcome the static friction force. In perspective A, the equation μmg=a indicates that a is the actual rate of acceleration the vehicle is traveling, even though the vehicles tires have not yet overcome the static friction.
In perspective B, the block is not analogous to the vehicle, but rather seem more analogous to the tires.
So, [μmg = ma] = [.5(1000kg)(10m/s) = 1000kg(a)] = a = 2m/s^2
In perspective A, the car is already in motion and traveling at a rate that is approaching 2m/s^2 before skidding.
However, in perspective B, the block is not in motion at anytime until after 2m/s^2.
But what does that mean?
With the car you can actually measure the vehicles acceleration. With the block, there is no apparent acceleration occurring from 0m/s^2 to 2m/s^2, yet 'a' is the variable that determines whether the block will be set into motion.
So it seems like although it takes exactly the same acceleration to overcome the force of static friction in each case, the acceleration is visible in the scenario with the car and hidden (as it is hidden in the vehicle's tires) in the scenario with the block.
So the 'a' does not actually translate to motion in any object until after the object exceeds the acceleration μg.
I think I was confused by the vehicles motion vs the tire's motion.
Supposing μg = 1.999.../s^2 so the object begins sliding at, say, 2m/s^2. This does not mean the object actually accelerates at this rate because kinetic friction is already acting on the object from the moment it begins to move.
So my question is A) is Everthing I said so far correct.
B) Is the acceleration of an object at the moment it breaks free from static friction μg and then does it slow down very rapidly to a net acceleration of ((μs)(mg)- (μk)(mg))/m = (fs-fk)/m = F/m = a_net?
Or is the acceleration always a_net from the instant it is in motion?
Related to Mass is independent of tendency to break static friction?
1. What is static friction?
Static friction is the force that prevents two objects from moving relative to each other when they are in contact and at rest.
2. How is the tendency to break static friction determined?
The tendency to break static friction is determined by the magnitude of the force applied to the objects and the coefficient of static friction between them.
3. Why is mass independent of the tendency to break static friction?
Mass is independent of the tendency to break static friction because it only affects the overall force of the objects, not the coefficient of static friction which is determined by the materials and surface properties of the objects.
4. Does the shape or size of an object affect its tendency to break static friction?
No, the shape or size of an object does not affect its tendency to break static friction as long as the mass and coefficient of static friction remain constant.
5. How does the coefficient of static friction affect the tendency to break static friction?
The coefficient of static friction is directly proportional to the tendency to break static friction. A higher coefficient of static friction means a greater force is needed to break the friction and cause the objects to move.
  • Mechanics
  • Mechanics
12K
