Mass loss through gravitational radiation
In summary: This includes kinetic and potential energy, so there's no clear indication here that kinetic energy is completely excluded from the definition of mass.
madness
815
70
A system emitting gravitational radiation loses mass. But how is this explained in terms of the system. Take for example a neutron star with non-radial oscillations - this will emit gravitational waves, and lose mass. So does the number of particles in the star decrease? Or does the binding energy in the star decrease?
Astronomy news on Phys.org
The gravitational waves will not cause the system to lose mass. The waves are created at the expense of the kinetic energy of the system, not its mass. The oscillations will dampen, the mass stays the same.
From Gravitational Waves: Theory and Experiment by Michele Maggiore, page 108:
"Of course, a physical system that radiates GWs loses mass. The conservation of the mass M of the radiating body, expressed by eq. (3.43), is due to the fact that in the linearized approximation the back action of the source dynamics due to the energy carried away by the GWs is neglected"
Yes, the effective gravitational mass of the system as seen from a distance, taking into account all its internal kinetic energy and binding energy, decreases when it emits gravitational waves. This doesn't however mean that the system loses any massive particles, but mainly that the constituent parts of the system lose kinetic energy, as Janus already said.
What do you mean here by gravitational mass? In most modern books on special relativity, mass means invariant rest mass, which doesn't include any contributions from kinetic energy. Does this change in general relativity?
Janus said "the gravitational waves will not cause the system to lose mass".
The textbook said "Of, a physical system that radiates GWs loses mass".
Are you saying these are both right?
The invariant rest mass of a system, in both special and general relativity, includes internal kinetic energy (for example rotational energy and thermal energy) and binding energy.
It does not include the overall kinetic energy due to the movement of a system as a whole.
Here is a quote from the same textbook which seems to imply that rest mass and kinetic energy are independent:
"Dimensionally [tex] \frac{T^{00}}{c^2} [/tex] is a mass density but of course, besides the contribution due to the rest mass of the source, it also contains all contributions to [tex] T^{00} [/tex] coming from the kinetic energy of the particles which make up the source, contributions from the potential energy, etc. For sources that generate a strong gravitational field, such as neutron stars, the gravitational binding energy will also be important. Only for weak field sources, and in the non-relativistic limit, [tex] \frac{T^{00}}{c^2} [/tex] becomes the mass density."
This seems to be rather unhelpful in the way it uses the word "mass" in three different ways.
The phrase "the rest mass of the source" is clearly intended to refer to the rest mass of the component particles which make up the system. The overall effective mass density also includes all other forms of internal energy.
In Special Relativity (and loosely speaking in General Relativity too) the effective rest mass of an overall system is the invariant magnitude of the total four-vector energy and momentum added up (as a four-vector) for all components of the system (with appropriate factors of c for unit conversion):
[tex](mc^2)^2 = E_{total}^2 - (p_{total}c)^2[/tex]
The rest mass of a system of two or more particles is not exactly equal to the sum of the rest masses of the individual particles except when they are at rest relative to one another and there is no binding energy between them.
Related to Mass loss through gravitational radiation
1. What is mass loss through gravitational radiation?
Mass loss through gravitational radiation is the phenomenon where two objects orbiting each other lose energy in the form of gravitational waves, causing them to gradually come closer together and eventually merge.
2. How does mass loss through gravitational radiation occur?
Mass loss through gravitational radiation occurs due to the acceleration of massive objects, which creates ripples in space-time known as gravitational waves. As these waves travel through space, they carry away energy from the system, resulting in a decrease in the mass of the objects.
3. Can we observe mass loss through gravitational radiation?
Yes, we can observe mass loss through gravitational radiation using specialized detectors such as the Laser Interferometer Gravitational-Wave Observatory (LIGO). These detectors are designed to detect tiny changes in space-time caused by passing gravitational waves.
4. What are the implications of mass loss through gravitational radiation?
The implications of mass loss through gravitational radiation are significant in astrophysics and cosmology. It is a crucial factor in the evolution of binary systems, such as black holes and neutron stars, and can provide insights into the properties of these objects.
5. Is mass loss through gravitational radiation harmful to Earth?
No, mass loss through gravitational radiation is not harmful to Earth. Gravitational waves are incredibly weak by the time they reach Earth, and their effects are only measurable with highly sensitive instruments. Additionally, the amount of mass lost through this process is minuscule and would not have any significant impact on Earth's orbit or environment.
