Mass, luminosity and magnitude of a galaxy
In summary, the conversation discusses calculating the angular area and magnitude of a galaxy. The first equation is used to calculate the semi-minor axis (b) of the galaxy, and the area of the ellipse is determined by multiplying a, b, and π. The second equation is used to calculate the apparent and absolute magnitudes, with the addition of half of the light outside the ellipse. The relationship between magnitude and luminosity is discussed, and the formula for calculating magnitude from luminosity is mentioned. The final calculations for the apparent and absolute magnitudes are provided, with a note about a possible error in the problem's given value for b/a.
astroYEEET
A galaxy is located at a distance D = 20Mpc from the Sun.
The shape of the galaxy was observed to look like an ellipse with a semi major axis a = 22.6 ”and
a / b = 0.85 ratio
Half of the total light from the galaxy comes from this ellipse and the average brightness of the surface in the ellipse is about 24.7 mag / arcsec2.
A) Calculate the absolute magnitude (mag) that corresponds to the whole galaxy.
B) Determine the total mass of the stars in the galaxy (in solar masses) based on this relation:
mass / brightness = (M / M⊙) / (L / L⊙) = 2
1)S=m+2.5logA where S surface brightness, m apparent magnitude, A area of arcsec^2
2)M-m=5-5logD where M absolute magnitude and D distance
3)(I am not sure if this can be used because it is about two stars not one star(the sun here) and one galaxy)L1/L2=(M1/M2)^3.5
So i first calculated the angular area of the galaxy. a=22.6'' and a/b=0.85 => b = 26.588''( btw I do not know why a/b =0.85 since b is the semi minor axis). Then the area of the elipse is a*b*π =1887.745''. Then using the first equation we get an apparent magnitude of m=16.511.
Using the second equation we get M=-14.994. So if i am correct this is the answer for A and this is how far i have gone.
Any ideas about the second question will be appreciated. Thanks in advance for your help
First, I suspect they mean that b/a = 0.85, and b should be smaller than a. If possible, you should check with the people who gave you the problem and verify if this is an error in the problem. Second, you have forgotten the other half of the light that is outside the ellipse. You should add this in, which will increase the apparent luminosity and decrease the apparent magnitude.
Likes astroYEEET
How do i calculate the luminosity ?
Do you know the relation between magnitude and luminosity? So if half the light is included, you need to double the total luminosity to include the other half. What does this do to the magnitude?
Likes astroYEEET
So luminosity is the energy that is emitted by a star per second.
Then there is absolute and apparent magnitude where apparent magnitude is how bright the star seems to be( which depends and on it's distance) and absolute magnitude is actually the luminosity of a star on a logarithmic scale(It is how bright a star would be if it was from a distance from us of 10 parsecs).
I do not know any formula about the luminosity and the magnitude but i suppose that since luminosity increases the star seems brighter and that corresponds to smaller magnitude.
So how can i find how much does the magnitude decrease from the magnitude i have calculated?
For almost any work in astronomy, you need to understand the quantitative relation between the luminosity and the magnitude. Keep trying to answer my question of what happens to the magnitude when you double the luminosity. You could start here:
https://en.wikipedia.org/wiki/Magnitude_(astronomy)
Likes astroYEEET
So as searching i found this formula which relates magnitude and luminosity : m1-m1=2.5log(L2/L1)
and this : Mbol=4.72-2.5log(L/Lsun)
The first one is the one you want. So if you double the luminosity, L2/L1 = 2. Then how does m change?
Likes astroYEEET
If the luminosity doubles i suppose the change in magnitude will be log(2)
No. Look at the equation again.
Correct me if i do something wrong
At first Δm=2.5log(1)= 0
But because we have to take into account the other half of the light emitted the luminosity doubles so Δm=2.5log(2)= 0.752
That looks right now. So then what are the apparent and absolute magnitudes?
Likes astroYEEET
The apparent magnitude will be 16.511-0.752=15.759
And then the absolute magnitude will be equal to M-m=5-5logD => M=-15.746
I get a slightly larger number for m. I'm conviced they really mean b/a=0.85. There is no way the semi-minor axis (b) should be larger than the semi-major axis (a). But you'll have to decide whether to take them at their word or correct their mistake. Assuming b>a (wrong!), I think you did this part correctly.
Likes astroYEEET
Ok so i will correct this. Now how should i solve question B ?
Once you have the absolute magnitude of the galaxy, you can compare it to the absolute magnitude of Milky Way, which you can look up.
And how do i use the relation that they give me ?
Actually, now that I look at it, you don't need the absolute magnitude of the Miky Way. They have asked you to reference it to the sun. Once you have the absolute magnitude of the galaxy, you can compare it to the absolute magnitude of the sun, which should allow you to calculate Lgalaxy/Lsun. You already told me the relation between magnitude and luminosity in Post #7.
Likes astroYEEET
Ok so if my calculations are correct the problem is solved. Thanks for your continuous help and i hope one day i will be able to guide others solving their problems. By the way are you a physicist/astrophysicist ?
OK, good. I hope you did it correctly. Yes, I work as a researcher in astrophysics.
Likes astroYEEET
Cool. At what area of astrophysics ? Sorry for the questions about your career but i love astronomy .At junior high school i won at the astrophysics competition of my country, but i had stopped engaging with it for a while because reading that it needs a phd seemed to me a very difficult accomplishment(i still view it as a career possibility)
I'm not comfortable discussing this in the open forum. Send me a private message and we can discuss it.
Related to Mass, luminosity and magnitude of a galaxy
1. What is the definition of mass in relation to a galaxy?
Mass refers to the amount of matter contained within a galaxy. It is typically measured in units of solar masses, which is equivalent to the mass of our sun.
2. How is the luminosity of a galaxy measured?
Luminosity is a measure of the total amount of energy emitted by a galaxy per unit time. It is typically measured in units of watts and can be calculated by multiplying the surface brightness of the galaxy by its size.
3. What factors affect the magnitude of a galaxy?
The magnitude of a galaxy is affected by its distance from Earth, its size, and its luminosity. The farther away a galaxy is, the fainter its magnitude will appear to us. Similarly, a larger and more luminous galaxy will have a brighter magnitude.
4. How is the mass of a galaxy related to its luminosity?
The mass and luminosity of a galaxy are directly related, meaning that as the mass of a galaxy increases, so does its luminosity. This relationship can be used to estimate the mass of a galaxy based on its luminosity.
5. Can the magnitude of a galaxy change over time?
Yes, the magnitude of a galaxy can change over time. This can be due to various factors such as changes in the galaxy's luminosity or its distance from Earth. Supernova explosions and collisions with other galaxies can also cause a temporary change in a galaxy's magnitude.
