Mass of a composite particle using relativity.
In summary, the homework statement is that a photon collides with a stationary particle of rest mass and is absorbed. The equation for the velocity of the composite particle is found and is v= E*c/(E+m0*c^2). The mass of the composite particle is found to be m= E+m0*c^2/(\gamma*c^2). However, the solution for the total mass is not found correctly because it involves \gamma.
lukeharvey
A photon collides with a stationary particle of rest mass m0 and is absorbed.
Find the mass and velocity of the composite particle
Conservation of energy:
E + m0 * c^2 = \gamma * mt *c^2 where mt is the total mass
Conservation of momentum:
E/c = \gamma * mt * v
I used the attachment as a diagram for the two different frames.
I then solved for the velocity first and found that:
v= E*c/(E+m0*c^2)
I then solved for the mass (mt) and found:
mt = E+m0*c^2/(\gamma*c^2)
However i am not sure if the solution for the total mass is correct because it involves \gamma. If it is correct i was wondering if there was any way to simplify equation, and maybe substitute an expression in for \gamma, so it is not in the equation?
Thanks
Thanks
Why not plug your solution for [itex]v[/itex] into the definition of [itex]\gamma[/itex] and simplify?
I've tried this but it didnt seem to simplify and when i put it into the equation i found it made it even worse. Any ideas?
It simplifies fairly nicely for me... why don't you show me where you are getting stuck?
Im not the best with latex but i can show you the equation i got on here if you can understand it
So i got gamma = 1/(sqrt(1-((((E*c)/(E+m*c^2))^2)/c^2)))
lukeharvey said:
Im not the best with latex but i can show you the equation i got on wolfram alpha?
I got gamma is equal to the expression shown on wolfram alpha, and it doesn't seem to simplify nicely
wolframalpha.com/input/?i=simplfy+1%2F%28sqrt%281-%28%28%28%28e*c%29%2F%28e%2Bm*c%5E2%29%29%5E2%29%2Fc%5E2%29%29%29
The page won't load properly because of the ascii representations in the address, but I get
[tex]\frac{1}{\gamma}= \sqrt{1-\frac{v^2}{c^2}} =\frac{\sqrt{m_0^2c^4+2Em_0c^2}}{E+m_0c^2}[/tex]
which makes [itex]m[/itex] come out rather nicely as
[tex]m=\frac{\sqrt{m_0^2c^4+2Em_0c^2}}{c^2}=m_0\sqrt{1+\frac{2E}{m_0c^2}}[/tex]
But i seem to get:
[itex]\sqrt{1-\frac{E^{2}}{E^{2}+M_{0}^{2}c^{2}}}[/itex]
But now I am stuck thanks for all the help
lukeharvey said:
But i seem to get:
You are probably expanding [itex]v^2[/itex] incorrectly, remember
[tex](E+m_0c^2)^2\neq E^2+m_0^2c^4[/tex]
Ah its actually been one of those days, how can i not expand properly? Thanks a lot for the help :)
why not going to a system where the two initial particles move with equal and antiparallel spatial mommenta?
That way you can easily find the mass of the particle afterwards by asking the square of the 4mommentum to be invariant, because the M1 in that system will be at rest. "CM" system.
Then by a lorentz transformation I think, you will be able to find that system from your initial one, and so the mommentum of M1 as well at the "LAB" system.
Just a general idea, I am too tired to try it out myself right now, to see if it's simpler or not. I generally like more the invariance of 4mommentum during collisions rather than any other method, which would make me get lost with velocities etc...
FAQ: Mass of a composite particle using relativity.
What is the concept of mass in relativity?
The concept of mass in relativity is different from the traditional concept of mass in classical mechanics. In relativity, mass is not a constant value, but rather a variable that depends on the velocity of the object. This is known as relativistic mass.
How is the mass of a composite particle calculated using relativity?
The mass of a composite particle using relativity is calculated by taking into account the relativistic masses of each individual particle that makes up the composite particle. This calculation takes into consideration the velocities and energies of each particle.
What is the relationship between mass and energy in relativity?
In relativity, mass and energy are equivalent and are described by the famous equation E=mc^2. This means that mass can be converted into energy, and vice versa, under certain conditions.
How does the concept of mass in relativity affect our understanding of the universe?
The concept of mass in relativity has significant implications for our understanding of the universe. It helps us explain phenomena such as the relationship between mass and energy, the behavior of particles at high velocities, and the bending of spacetime in the presence of mass.
What are some real-world applications of understanding the mass of composite particles using relativity?
Understanding the mass of composite particles using relativity has many practical applications, such as in particle accelerators, nuclear reactors, and space travel. It also helps us make precise calculations in fields such as astrophysics, cosmology, and high-energy physics.
