Mass of an anti electron neutrino
In summary: The mass of an electron is not a constant value, it depends on its energy. The 0.511 MeV value is the "rest mass" - the mass of an electron when it is not moving (or when its kinetic energy is negligible compared to its rest mass). In beta decay, the electron will have some kinetic energy, so its total energy (including its rest mass) will be higher. However, it is still useful to know the rest mass, as it allows us to compare the kinetic energy of the electron to its rest mass energy (via E=mc^2). This is important for understanding the conservation of energy in the beta decay process.As for the mass of an anti electron neutrino, it is much more difficult
adimantium
I can't seem to find the mass of an anti electron neutrino in MeV. I found that in beta radiation one down quark breaks into an up quark, an electron, and an anti electron neutrino. The mass in MeV of a down quark is 4.8, the mass of an up quark is 2.4 MeV, the mass in MeV of an electron is 0.511 MeV. So the mass of an anti electron neutrino should be 1.889 MeV. However I can't find a place to make sure I am right. Thank you and forgive me if I'm wrong.
Your calculation ignores the fact that the beta decay products typically carry kinetic energy. This makes it hard to use beta decay to measure the neutrino mass, since the neutrino masses are very small, probably around a few hundredths of an eV. The kinetic energy of the electron, for example, is typically at least a few % of its mass, so around a few thousand eV, which is around 5 orders of magnitude larger than the expected neutrino mass. An experiment would need a high sensitivity to measure the small neutrino mass.
Furthermore, because of neutrino oscillations, current experiments have not been able to measure the value of the electron neutrino flavor eigenstate.
There is a proposal for a new experiment sensitive to a mass of around ##0.2~\mathrm{eV}##. A review of this and other experiments is here. It may be possible in the next few years to have a direct measurement of a neutrino mass.
In addition to the good post of fzero: you cannot consider the quarks as isolated particles. The decay is a process of the whole nucleon or even the whole nucleus (if you don't have a free neutron). The released energy corresponds to the mass difference between initial and final nucleus (or neutron->proton for a free neutron).
Those light quark masses are problematic anyway - it is hard to measure them as you cannot see them as isolated quarks, and the values have a large uncertainty.
So the measurements that suggests that the electron neutrino may have a negative mass-squared value are wrong ?
which measurements gave such a thing? if such a thing exists then it's a tachyon.
Also a technique people use to measure the neutrino masses are the Kurie Plots:
http://www2.warwick.ac.uk/fac/sci/physics/research/epp/exp/detrd/amber/neutrinomass/
For the negative masses you would be in the blue line of the Kurie Plot.
There are no measurements that are incompatible with real and positive neutrino masses.
And how is this related to the old thread from 2013?
I didnt want to open a new thread ...
So what are these guys talking about ?
http://www.sciencedirect.com/science/article/pii/S0370269398008247
"The unphysical result of the negative mass square of the electron neutrinos recently reported in several tritium β-decay experiments, is one of the most attractive subjects among remaining physical problems"
http://arxiv.org/ftp/arxiv/papers/0909/0909.2104.pdf
"In view of erroneous and unphysical mass results obtained by some earlier experiments in β-decay"
Beta decay experiments set out to determine the neutrino mass found their best fit was for negative mass squares. However, the result were still compatible with positive mass squares and so there was never really a big problem. The expriments are therefore not wrong, they are simply not sensitive enough to make a definite statement.
As is often the case, physicists like to theorize what could cause a result for which there is only a weak hint in case more precise measurements would confirm it.
Those are old measurements - the linked paper is from 1998 and refers to papers from 1991 to 1995.
A more recent and more precise measurement has been done in http://www.physik.uni-mainz.de/exakt/neutrino/en_experiment.html, they quote a squared mass of ##-1.6 \pm 2.5 \pm 2.1 eV^2## - this is an example where the best fit value is negative, but a small positive mass is well in agreement with the measurement (less than 1 sigma away).
The combination of neutrino oscillation based mass eigenstate differences, Planck cosmic background radiation measurements, and other astronomy data, suggests a lightest neutrino mass eigenstate of about 0.001 eV or less in a normal mass hierarchy, and a bit more (but still well under 0.01 eV) in the case of an inverted neutrino mass hierarchy. Determining the mass hierarchy definitively should be possible within the next few years. Direct measurement of the absolute neutrino masses will take a longer period of time.
As noted above, however, in the vast majority of circumstances, neutrinos will have much more kinetic energy than they have rest mass. A neutrino with GeV kinetic energy (travelling at very nearly the speed of light) wouldn't be terribly exceptional.
Wait, actually I have a question of my own, how did you know the mass of an electron is .511? Is that the rest mass? But if it is why would you want rest mass since in β rad. it also has momentum?
If by "the next few" you mean within 2 or 3 years, I am afraid this statement is misleading. The current generation of neutrino oscillation experiments simply do not have the sensitivity to provid this kind of measurement unless you are very lucky with statistical fluctuations (conversely you could also get unlucky and rule out the correct hierarchy). There most certainly will be a hint or two, but a measurement at 3 (or preferably 5) sigma will probably have to wait for the new generation of experiments. The NOvA experiment which just recently started getting events and will run for 6 years would reach 3 sigma only if they are lucky *and* the CP phase is favorable (see http://www-nova.fnal.gov/plots_and_figures/1200_NOvA_New_Sensitivity_Plots/51_HierarchySignificance_with_t2k.png). All other experiments with sensitivity to the mass hierarchy are still on the drawing table:
JUNO: New reactor neutrino experiment in China. They are looking for teeny tiny changes in the oscillation pattern as a function of energy. It is still not clear to me whether they will be able to reduce the energy uncertainties and control the linearity of their energy scale to high enough precision to make the measurement. But it seems they are going to build it anyway, it worked for the Daya Bay experiment ...
PINGU: Measurement of atmospheric neutrino oscillations by a low energy extension of IceCube/DeepCore. Could measure the mass hierarchy very fast if it is constructed and the parameters are favorable. It needs to find funding and to be constructed. The american community did not seem overly enthusiastic about the idea.
INO: Indian magnetized iron detector. They have significantly improved their prospects of measuring the mass hierarchy using atmospheric neutrinos by suggesting inclusion of hadronic information directly into their analysis. Still needs to be built but India seems intent on doing so. Could perhaps have a 3 sigma result around 2025 or so.
Future long baseline experiments: Accelerator based experiments being suggested for different locations and configurations. The far detector of these experiments could most likely measure the mass hierarchy using atmospherics even if the long baseline experiment itself could not (as is the case in T2HK). None of these experiments are currently approved/funded and they will need additional time for construction. I would be surprised if they have significant results by 2025.
So, Smirnov is basing these statements on the PINGU idea, which he was one of the first to discuss (the original paper here or on arXiv). The estimates in his paper are based on a very crude method of counting events and if I remember correctly it did not account for parameter degeneracies between the hierarchies. I would put more trust into the sensitivity analyses performed by the PINGU collaboration itself.
A recent PINGU conference talk can be found at this link from the NuFact conference last week. The PINGU sensitivity to the mass hierarchy is shown on page 19 together with the statement that it will be fully constructed in 2020 at the earliest (and add up to 4 years for getting sensitivity). In the last backup slide there is also a timeline sensitivity plot including some of the experiments I mentioned above. These should be taken with a big grain of salt as they tend to get outdated very fast as experimental configuration, running plan, and funding changes quite rapidly.
"Mass" is always "rest mass", apart from ancient textbooks and bad TV shows.
Related to Mass of an anti electron neutrino
What is the mass of an anti electron neutrino?
The mass of an anti electron neutrino is extremely small and is currently believed to be less than 1 electronvolt (eV). This is significantly smaller than the mass of other subatomic particles, such as protons and neutrons, which have masses in the range of 1 billion eV.
Can anti electron neutrinos have varying masses?
Yes, anti electron neutrinos can have varying masses depending on their energy levels and the environment they are in. They can also change between different types of neutrinos, which can affect their mass.
How is the mass of an anti electron neutrino measured?
The mass of an anti electron neutrino is difficult to measure directly because they interact very weakly with other particles. Scientists use various methods, such as studying the decay of radioactive elements or analyzing data from high energy particle collisions, to indirectly measure the mass of anti electron neutrinos.
Why is the mass of an anti electron neutrino important?
The mass of an anti electron neutrino is important in understanding the fundamental properties of the universe and the behavior of subatomic particles. It can also provide insights into the nature of dark matter and the origins of the universe.
Is the mass of an anti electron neutrino constant?
No, the mass of an anti electron neutrino is not constant and can change depending on factors such as energy levels and interactions with other particles. Scientists are still researching and studying the behavior of neutrinos to better understand their mass and its variations.
