Mass of an element required for a chemical reaction equation
In summary, we can calculate the required amount of aluminium (Al) needed for a reaction by converting the given mass of 9.65 kg to 9650 g and using the molar mass of Al2O3, which is 101.96 g/mol. We then find that 9650 g of Al2O3 is equivalent to 94.65 moles of Al2O3. Since 2 moles of Al are needed to make 1 mole of Al2O3, we multiply 94.65 moles by 2 to get 189.3 moles of Al required. This is equal to 189.3 mol x 26.98 g/mol = 5.107x103
Kiah Palmer
Calculate the mass of 80% pure aluminium required to produce 9.65 kg of aluminium oxide. Hint: First calculate the mass of pure aluminium.
Al + O2 -> Al2O3 = 4Al + 3O2 -> 2Al2O3
Conversion: 9.65 kg = 9650 g
Mass Al = 26.98 g/mol
Molar Mass Al2O3 = (2 x 26.98) + ( 3 x 16.00) = 101.96 g/mol
Mol Al2O3 = 9650 g / 101.96 g/mol = 94.65 mol
Mol Al Required = 94.65 mol x 2 = 189.3 mol
Mass 100% Al required = 189.3 mol x 26.98 g/mol = 5.107x103 g
Mass 80% Al required = 5.107x103 g x (80/100) = 4.086x103
I believe this is correct, however, if it isn't could someone please let me know where I went wrong. I will be handing it in as is, but it would still be nice to know. I had looked up the answer after completing it, but the way that person completed it doesn't look right to me ( and has a different answer for the last section. I will include the answer I had found below, and you will notice that I had most of it, however, if their last section is correct then an explanation of how would be greatly appreciated. Thanks!The molar mass of Al2O3 is 101.96 g/mole
Mass of aluminium = 26.98 g/mole.
So 9650 g Al2O3 = 94,645 moles.
And to make 1 mole Al2O3 you need 2 moles Al.
Then you need 189,29 moles Al = 189,29*26,98 g = 5107,04 g.
And if 5107,04 g are 80%, then is 5107,04*100/80 = 100% = 6383,8 g needed.
OK
103, please format properly (but yes, the result is OK)
That's 80% of a required mass, and you need something 80% of which is the required mass, do you see the difference?
Ah! ok, so the answer that I had found when looking afterwards is in fact the correct answer! It actually makes sense now! thanks again! :) I did hand it in the way I Have done it, but at least now I will know where I went wrong. :)
Likes berkeman
Related to Mass of an element required for a chemical reaction equation
What is the mass of an element required for a chemical reaction equation?
The mass of an element required for a chemical reaction equation is the amount of that element that must be present in order for the reaction to occur. It is usually measured in grams or moles.
How do I calculate the mass of an element required for a chemical reaction equation?
To calculate the mass of an element required for a chemical reaction equation, you will need to know the balanced chemical equation and the molar mass of the element. Multiply the coefficient of the element by its molar mass to get the mass required in grams.
Why is the mass of an element required for a chemical reaction equation important?
The mass of an element required for a chemical reaction equation is important because it determines the amount of that element needed for the reaction to take place. If there is not enough of the element present, the reaction may not occur or may not reach completion.
Can the mass of an element required for a chemical reaction equation change?
Yes, the mass of an element required for a chemical reaction equation can change depending on the amount of reactants present and the conditions of the reaction. It is important to use the correct mass for each specific reaction.
What happens if there is excess mass of an element in a chemical reaction equation?
If there is excess mass of an element in a chemical reaction equation, it will not affect the outcome of the reaction. The excess mass will remain unreacted and will not be included in the products of the reaction.
9K
