Mass of Bound Particles & Mass-Energy Equivalence
In summary: And this should lead to the production of new particles, which should be characterised by their mass.In summary, the mass defect in nuclei is caused by the fact that the binding energy of the nucleus is positive, whereas the mass of a nucleon is greater than the sum of the constituent quarks. This is because the potential energy of a bound system counts as a subtraction to the total mass of the system.
Gene Naden
321
64
I am confused about the mass-energy equivalence relation as it applies to nuclei and nucleons. For nuclei, I read of a "mass defect." Naively, I supposed that since it is a collection of nucleons bound together, it has a negative binding energy and this is the reason for the term "mass defect." For nucleons consisting of quarks bound together, I again supposed that there is a negative binding energy and that there should be a mass defect. Yet I read that the mass of a nucleon is greater than the sum of the constituent quarks. No mass defect.
I am wondering if the potential energy of a bound system counts as a subtraction to the total mass of the system.
No, the binding energy of a nucleon is positive. Note that there is no analog of isolated quarks here - these simply don't exist.
Edit: Fixed a word. Was still correct before but didn't express what I wanted to say.
For these purposes, I believe we have no choice but to set the potential energy to zero in the limit that the system's constituents are infinitely far apart. The closer the constituents, the greater the absolute value of the potential energy. The potential energy is negative if it's associated with an attractive force, and positive if it's associated with a repulsive force.
So yes, binding energy (attractive force) counts as a "subtraction" to the system mass.
I don't think one can really understand the nucleon situation without quantum chromodynamics, which is pretty advanced stuff that's way beyond me. But maybe heuristically we can regard the strong force as repulsive at the scale in question? Not sure. Might have something to do with the Pauli exclusion principle: https://en.wikipedia.org/wiki/Nuclear_force#Description
Thanks for your response, Sienna.
mfb said:
No, the binding energy of a nucleus is positive. Note that there is no analog of isolated quarks here - these simply don't exist.
The binding energy, however lowers the energy as compared to the corresponding free particles. A composite particle has the invariant mass
$$M=m_1+m_2+\cdots+m_n-E_{\text{B}}/c^2,$$
when the binding energy is taken as positive (for, e.g., nuclei with the protons and neutrons as constituents).
Likes Gene Naden
Oh, I meant nucleon where I wrote nucleus. It was still true, but not what I wanted to say.
Thanks, Venhees.
Your formula for the invariant mass looks familiar from my grad school days. It certainly seems right. However, I have several times encountered the statement that a nucleon weighs more than the sum of its quarks. For example, a neutron is composed of two downs and an up.
##m_u=2.3 MeV##
##m_d=4.8 MeV##
##m_{neutron}=939 MeV##
##m_{neutron} >> 2m_d+m_u##
This is another case. The masses of the hadrons composed of light quarks are almost completely from confinement of QCD, and it's not really well understood since it's a non-perturbative property of QCD. It is, however, known to be correct from lattice-QCD calculations of the hadron spectrum which today agrees at the percent level with the measured hadron masses.
An intuitive picture is provided by the MIT bag model. There the idea is that the three quarks are confined in a "blob" (the "bag") with a size in the order of magnitude of the nucleon radius (which is roughly around 1 fm). In this model you can think of most of the mass of the nucleon as being provided by the kinetic energy of the 3 light quarks. Their mass is almost negligible.
On a more abstract effective-field-theory level you may say that there are at least two possible ways to generate mass: (a) the socalled trace anomaly and (b) the formation of a "quark condensate", i.e., ##\langle \bar{\psi} \psi \rangle \neq 0##.
One way to check this is provided by heavy-ion collisions, i.e., high-energy collisions of heavy nuclei, as is done at the Relativistic Heavy Ion Collider (RHIC) at the Brookhaven National Lab (BNL) and at the Large Hadron Collider (LHC) at CERN. There one expects that in the collision a fireball of hot and dense matter is formed, which in the beginning is so hot and dense that the relevant degrees of freedom are partons (i.e., quarks and gluons) rather than hadrons, forming what's called a quark-gluon plasma (QGP). This fireball rapidly expands and cools down. It's living only for a time of around 10 fm/c.
It's very hard to get information of the hot and dense partonic and hadronic state. All you can measure with the detectors is the final hadronic state, and from the patterns of all kinds of observables one has to calculate back to the source it may come from.
However, there's one particular "rare probe", which let's us look into the hot and dense medium, i.e., lepton-antilepton pairs (either elektron-positron pairs or muon-antimuon pairs), the socalled "dileptons". The dileptons are produced from vector-like excitations of the QGP and from vector mesons in the hot hadronic phase of the fireball evolution. Since the dileptons do not interact via the strong interaction they suffer practically no final-state interaction, so that its mass and momentum spectra provide a space-time weighted average over the "thermal evolution" of the hot and dense fireball. Particularly at low invariant dilepton masses, ##2 m_{\ell} \leq M_{\ell^+ \ell^-} \lesssim 1 \mathrm{GeV}## the main sources are in-medium ##q\bar{q}## annihilation of quarks in the partonic phase and in-medium decays of the light vector mesons ##\rho##, ##\omega##,and ##\phi##. Since hat high enough temperatures and densities the hadrons dissolve into partons, one expects drastic changes of these particles' mass spectra, which should be reflected in the dilepton-production rates and thus the dilepton-invariant-mass spectra. Indeed, that's what has been observed over the about last 20 years (beginning with experiments at the SPS at CERN and now also at RHIC and LHC, but also at lower collision energies as at the Heavy-Ion Research Center (GSI) here in Germany): Compared to a naive expectation from dilepton production in proton-proton collisions, just scaling up the cross section with the number of nucleon collisions within the heavy-ion collision, you get an enhancement of dileptons at invariant masses just below the ##\rho##-##\omega## masses (around 770 or 780 MeV, respectively) and a tremendous enhancement in the very-low-mass tails.
All this is well described by in-medium dilepton rates from effective hadronic field theory in the hadronic and in-medium ##q\bar{q}## annihilation rates from thermal QCD (including in-medium modifications of the quarks in the socalled Hard-Thermal-Loop expansion (HTL)), appropriately folded with a model for the hot and dense expanding and cooling fireball (ranging from simple fireball parametrizations over ideal and viscous relativistic hydrodynamics, and microscopic relativistic transport simulations and combinations thereof) for the time evolution of the sources. As turns out, the main medium effect on the vector mesons within these models is a tremendous broadening of the mass spectrum of the light vector mesons with quite small changes in their mass, merging smoothly into the ##q\bar{q}## annihilation rates from thermal QCD, implying the restoration of chiral symmetry (from lattice QCD at baryochemical potential ##\mu_B=0## this occurs as a cross-over at temperatures around 150-160 MeV).
From this one can conclude that the main mass-generation mechanism of hadrons is due to the trace anomaly, i.e., the anomalous breaking of scale invariance of QCD, and only a small part is provided by the quark condensate, which is the order parameter for chiral symmetry, i.e., it should melt around the cross-over temperature, and this is indeed seen in the lattice-QCD calculations. The same lattice calculations show that the gluon condensate (related with the contribution of the trace anomaly to the hadron masses) is pretty stable in this temperature region, melting at quite higher temperatures only.
For a recent review on dilepton (and photon) production in heavy-ion collisions, see
https://th.physik.uni-frankfurt.de/~hees/publ/habil.pdf
Likes PeterDonis and Greg Bernhardt
Thank you for that thoughtful, detailed response, vanhees. It gives me something to look forward to understanding. I have in my mind a picture of a bag of fast-moving particles, though that may not be correct.
Likes Greg Bernhardt
Right, the bag model is not completely right for sure, it's a oversimplifying picture, but on the other hand in my opinion we don't have a full understanding of the nonperturbative phenomenon of confinement yet, i.e., you have not only something to look forward to understanding, but perhaps for doing your own research at a university or a lab!
FAQ: Mass of Bound Particles & Mass-Energy Equivalence
How is the mass of bound particles measured?
The mass of bound particles is typically measured using a mass spectrometer, which separates particles based on their mass-to-charge ratio. This allows scientists to determine the mass of individual particles within a sample.
What is the relationship between mass and energy in the context of mass-energy equivalence?
In the theory of relativity, mass and energy are considered to be two forms of the same thing. This means that mass and energy can be converted into each other, and the amount of energy contained in an object is equal to its mass multiplied by the speed of light squared (E=mc^2).
Can particles have a negative mass in the context of mass-energy equivalence?
No, according to the theory of relativity, particles cannot have a negative mass. The mass of a particle is always positive, and it is the amount of energy that determines the direction and magnitude of the particle's motion.
How does mass-energy equivalence impact our understanding of the universe?
Mass-energy equivalence is a fundamental concept in physics that has led to a deeper understanding of the universe. It helps explain the relationship between mass and energy, and has been used in the development of technologies such as nuclear power and nuclear weapons.
What are some real-world applications of mass-energy equivalence?
One of the most well-known applications of mass-energy equivalence is in nuclear power. The conversion of a small amount of mass into a large amount of energy is what powers nuclear reactors. Other applications include medical imaging technologies, such as PET scans, which use the conversion of mass into energy to create images of the body, and nuclear weapons, which use the immense energy release from the conversion of mass into energy for destructive purposes.
