Mass of escaped air from a cylinder
In summary, the question asks for the mass of air that escapes from a compressed air cylinder when it is moved from a store at 7 °C to a workshop at 27 °C and a safety valve is activated. The correct answer is 0.33 kg, but the approach used to solve the problem is unclear and does not consider the ambient temperature difference as the main factor causing the air to escape. Using the perfect gas law, PV = nRT, would provide a more accurate and logical solution.
moenste
711
A cylinder containing 19 kg of comperessed air at pressure 9.5 times that of the atmosphere is kept in a store at 7 °C. When it is moved to a workshop where the temperature is 27 °C a safety valve on the cylinder operates, releasing some of the air. If the valve allows air to escape when the its pressure exceeds 10 times that of the atmosphere, calculate the mass of air that escapes.
Answer: 0.33 kg
2. The attempt at a solution
Density of air = 1.293 kg m-3
Mass = Volume * Density
VolumeStore = 19 / 1.293 = 14.7 m3
VWorkshop = (pStore * VStore * TWorkshop) / (TStore * pWorkshop) = (9.5 p0 * 14.7 * 300.15) / (280.15 * 10 p0) = 14.95 m3
MassWorkshop = 14.95 * 1.293 = 19.33 kg
19.33 - 19 = 0.33 kg... fits the answer but why the mass is 19.33 after the escape? What's wrong?
Answer: 0.33 kg
This appears to be the density of air at standard temperature and pressure. It's not clear how this relates to the problem.
When air is compressed to 9.5 times atmospheric pressure, its density increases.
The air is compressed and kept in a cylinder in a store, or storage room. It's not clear why you are calculating the volume of 19 kg of air at standard pressure and temperature. (See above)
Your approach to solving this problem is puzzling.
Likes moenste and Chestermiller
Answer: 0.33 kg
As far as the mass of air escaping from the cylinder is concerned, the pressure inside the workshop is immaterial, unless you assume the workshop is airtight, which few are.
The ambient temperature difference between the store room and the workshop is what is causing the air to want to expand inside the cylinder.
Concentrate on what is happening inside the compressed air cylinder. Use the perfect gas law, PV = nRT, to find out the details.
Likes moenste
Related to Mass of escaped air from a cylinder
1. What is the mass of escaped air from a cylinder?
The mass of escaped air from a cylinder depends on several factors such as the volume of the cylinder, pressure inside the cylinder, and temperature of the air. It is not possible to determine the exact mass without knowing these variables.
2. How can the mass of escaped air from a cylinder be measured?
The mass of escaped air from a cylinder can be measured using a scale or balance. The cylinder should be weighed before and after the air escapes to determine the difference in mass. This method is most accurate when the cylinder is closed and airtight.
3. Will the mass of escaped air from a cylinder change over time?
Yes, the mass of escaped air from a cylinder will change over time as the air inside the cylinder will continue to escape until the pressure inside the cylinder is equal to the pressure outside. The rate of change will depend on the size and shape of the cylinder, as well as the temperature and pressure of the surrounding environment.
4. Does the type of gas in the cylinder affect the mass of escaped air?
Yes, the type of gas in the cylinder can affect the mass of escaped air. Different gases have different densities, which will affect the weight of the escaped air. For example, helium is lighter than air and will escape more quickly, resulting in a lower mass of escaped air compared to a heavier gas like carbon dioxide.
5. How does the temperature of the air in the cylinder affect the mass of escaped air?
The temperature of the air in the cylinder can affect the mass of escaped air in two ways. First, as the air warms up, it will expand and take up more space, resulting in a decrease in pressure and a smaller mass of escaped air. Second, warmer air is less dense than cooler air, so the same volume of air at a higher temperature will have a lower mass.
  • Mechanical Engineering
  • Mechanics
