Mass of Higgs, W and Z bosons going to zero at high energies
In summary, the success of renormalisation in the Electroweak sector of the Standard Model relies on the fact that at high energies, the masses of the Higgs, W, and Z bosons tend towards zero. This can be seen in the ratio of renormalized masses over the cutoff scale, ##M /\Lambda \rightarrow 0##. However, there is no guarantee that this will still hold if a different Higgs field with a different self-interaction is proposed. The form of the potential for the Higgs can affect the renormalisation process, and if terms with a mass dimension larger than 4 are introduced, the theory will be superficially non-renormalisable.
Renormalised
Hi Everyone! Hope everyone is really enjoying pushing the Physics frontiers!
Really need some help here. In the Electroweak sector of the Standard Model, it is apparently the case that the success of renormalisation to remove the Ultraviolet Divergence relies on the fact that at high energies the masses of the Higgs, W and Z bosons tend towards zero.
Could someone please provide me as many references to this as possible? Particularly references that would be accessible to a doctoral student, which would be greatly appreciated. I have not been able to find anything on the internet much about this at all, though I have always been aware of the fact.
Wold also greatly appreciate the answer to the question as to whether the Symmetry of the Higgs Lagrangian enables all this to happen? Is the symmetry of the Higgs Lagrangian driving this, and if so, how is this happening?
Most grateful for your assistance.
Do you have a specific reference that you have in mind? It would make it easier to discuss your question. Usually, what is used is not that the masses tend to zero, it is rather that the ratio o the renormalized masses over the cutoff scale goes to zero, ##M/\Lambda \rightarrow 0##. But again, it would be better to have a specific book/paper to focus on.
Thanks very much for your help. Happy for you to choose the reference. It would be handy if it were online. Below is the question which I am trying to answer:-
I have proposed a variant of the Standard model where the usual Higgs field (Lagrangian) expression breaks to a different expression than the usual one.
In the conventional theory (Standard Model), all particles lose their masses at high energies. The usual Higgs potential is symmetric, and at high energies the behaviour of the whole system becomes identical to that as if the vacuum Higgs condensate would be zero and the particles were massless. The latter fact helps to organize cancellation of ultra-violet divergences and makes the whole theory renormalizable. This is the key
point for which the Higgs mechanism was originally invented.
My question is whether, with this different scenario, will the theory still evolve to a massless W/Z boson regime at high energies?
Very grateful for your help!
It would also be good to know the following: if you proposed a Higgs Lagrangian which is only different in that it has a different self-interaction to the usual one, but which is still symmetric under gauge transformations, and which breaks in the usual way as φ → v + H(x), will the EW theory still be renormalizable with this change?
That is, does the form of the potential for the Higgs matter a hoot in so far as renormalisation is concerned?
Thanks again for your help!
Yes. If you introduce any terms that have a mass dimension larger than 4 your theory will be superficially non-renormalisable.
Thanks very much!
Thanks very much for your answers.
So I take it that if I propose a Higgs field which is only different from the usual Higgs by having a different self-interaction with no terms in Φ of a higher power than 4, and it functions in exactly in the same way as the Higgs does in the usual Standard Model, then the EW theory with this change will still be renormalizable?
Thanks for your help again
There is no other self-interaction than the ##\phi^2## and ##\phi^4## terms present in the SM that does not explicitly break SU(2) invariance. Also, please take note on the forum rules regarding personal theories.
Very great thanks again. This is for a seminar and we have been asked a very tough question. Renormalisation is apparently a vast area with sections of it being also vast research areas in their own right!
Each of us has to propose some change to the Lagrangian of the Standard Model, which will not affect renormalizability. It does not have to be right of course! Each model will be discussed in the seminar and shown what problems it will produce (if any). We can stay in the Electroweak sector only, if we like. This is not for assessment of participants but rather, a sharp learning curve.
The original expression -μ2/2(ΦΦ) - λ/4(ΦΦ)2 is clearly unique. But after spontaneous symmetry breaking, this is expressed in terms of the field H, and there are variants of the self-interaction polynomial in H which will still be invariant under SU(2). Again, not asking whether this is right or not.
The suggestion I wish to pursue is that if you vary the SM Lagrangian now expressed in terms of H, by only changing the self-interaction of the Higgs ( H(x) ) and keep the order of the polynomial no higher than 4, and ensure that the interaction is still invariant under SU(2), will this still formally preserve renormalizability?
Thank you so much for your help.
The SM after symmetry breaking already includes other terms in the potential. This is, for example, where the fermion and gauge boson masses come from. In short, the SM already includes all of the terms it can while obeying its proposed gauge symmetries. If you introduce new terms after symmetry breaking you are going to have to explain what kind of term in the Lagrangian before symmetry breaking that it came from. In order to make alterations to the SM Lagrangian while satisfying gauge symmetry you would have to add new fields (with possibly one exception that I will not mention explicitly since it is your seminar question).
FAQ: Mass of Higgs, W and Z bosons going to zero at high energies
What is the significance of the mass of Higgs, W, and Z bosons going to zero at high energies?
The mass of a particle is an important characteristic that determines its behavior and interactions with other particles. At high energies, the mass of the Higgs, W, and Z bosons approaching zero suggests that these particles may become massless, which could have significant implications for the fundamental forces and structure of the universe.
How does the mass of the Higgs, W, and Z bosons affect the Standard Model of particle physics?
The Standard Model is a theory that describes the fundamental particles and their interactions. The mass of the Higgs, W, and Z bosons is an integral part of this model as it explains how particles acquire mass. If the mass of these bosons goes to zero at high energies, it could challenge the current understanding of the Standard Model and potentially lead to the development of new theories.
What evidence do we have for the mass of Higgs, W, and Z bosons approaching zero at high energies?
This phenomenon has been observed in experiments at high-energy particle colliders, such as the Large Hadron Collider. These experiments have provided evidence for the existence of the Higgs, W, and Z bosons and have measured their masses, which have been found to decrease at high energies.
Could the mass of the Higgs, W, and Z bosons actually reach zero at high energies?
This is currently a topic of debate and ongoing research in the scientific community. While current evidence suggests that the mass of these particles approaches zero at high energies, it is not yet known if they will actually become massless or if there are other factors at play that may prevent this from happening.
How does the concept of symmetry breaking relate to the mass of the Higgs, W, and Z bosons at high energies?
The Higgs, W, and Z bosons are believed to be responsible for the breaking of symmetry in the universe, which is necessary for particles to acquire mass. At high energies, the mass of these bosons approaching zero may be an indication of the restoration of symmetry, which could have far-reaching implications for our understanding of the fundamental forces and structure of the universe.
