Mass of ions with respect to amu
  • Thread starter johnny_b_good
  • Tags
    Ions Mass
In summary, the current amu system assigns values to all atoms based on their relationship to Carbon-12. When calculating the mass of ions, the mass of the electron is often ignored because its weight is much smaller than the proton's. However, for more precise calculations, it can be taken into account.
johnny_b_good
Dear all,
I have a question concerning a basic chemistry topic: atomic mass units. The current amu system defines 1 amu = 1/12 of a Carbon-12 isotope (about 1.66 * 10^-27 kg). Therefore, every other atom is assigned a amu value based upon its relationship to Carbon-12.
My question concerns ions. Given the following elementary reaction,
Na+ + Cl- ⇔ NaCl
Any general chemistry student can calculate mass of Na+ required to produce one mole of NaCl. However, when calculating the value for Na+ we calculate the value using 22.99 g/mol. Why is that? I understand that this value is a weighted average of relative abundances of Na isoptopes. But why do we ignore the mass of the electron? Is it due to the fact that an electron weighs about 1/1836 the mass of a proton? If this is true, then isn't this assumption limited (for as you increase the number of moles, the number of atoms increases in relation to avogadros number... which would eventually make the mass of the one less electron a non=ignorable factor). Thanks for the help!
Chemistry news on Phys.org
johnny_b_good said:
Dear all,
Na+ + Cl- ⇔ NaCl
You've got the right idea. If you wanted to calculate more precisely, you could try and find more precise data, with more decimal places. An electron weighs 0.000544662 amu, so you could subtract that amount from your value. Most of the time this will be insignificant.
If you're looking at millions of moles, this value will be larger, but your error percentage will remain the same.
Related to Mass of ions with respect to amu
What is the definition of "Mass of ions with respect to amu"?
The mass of ions with respect to amu refers to the measurement of the relative mass of an ion in atomic mass units (amu). This unit is based on the mass of a single atom of carbon-12, which is assigned a mass of exactly 12 amu.
How is the mass of ions with respect to amu calculated?
The mass of ions with respect to amu is calculated by adding the masses of all the individual atoms that make up the ion. The mass of each atom is determined by its atomic mass, which is the sum of the number of protons and neutrons in its nucleus. This total mass is then divided by the mass of a single atom of carbon-12 to get the mass in amu.
What is the significance of using amu to measure the mass of ions?
Amu is a useful unit for measuring the mass of ions because it allows for easy comparison between different ions and elements. Since all atoms of carbon-12 have the exact same mass, using this unit allows for precise and consistent measurements.
How do the mass of ions differ from the mass of neutral atoms?
The mass of ions differs from the mass of neutral atoms because ions have an unequal number of protons and electrons. This imbalance in charge causes the ion to have a different mass and chemical properties than its neutral atom counterpart.
How does the mass of ions affect their behavior in chemical reactions?
The mass of ions can greatly affect their behavior in chemical reactions. Heavier ions tend to have a slower reaction rate, while lighter ions can react more quickly. Additionally, the mass of ions can also determine the type of chemical bonds they can form and their overall stability in a reaction.
17K
