Mass on incline will it slip or stick?
A block of mass m on a 20-degree slope is connected to a 2.0 kg hanging mass via a pulley, with coefficients of static and kinetic friction of 0.80 and 0.50, respectively. The discussion centers on calculating the minimum mass m that will not slip down the incline and the acceleration if it is nudged. The initial attempt to solve for the minimum mass incorrectly omitted the gravitational force acting on the block on the slope. For part B, it is emphasized that the kinetic friction coefficient should be used instead of the static one. Accurate calculations require considering all forces acting on the system.
charan1
Figure shows a block of mass m resting on a 20* slope. The block has coefficients of friction uS=0.80 and uK=0.50 with the surface. It is connected via a massless string over a massless, frictionless pulley to a hanging block of mass 2.0 kg.
Part A:
What is the minimum mass m that will stick and not slip?
Part B:
If this minimum mass is nudged ever so slightly, it will start being pulled up the incline. What acceleration will it have?
Fnet=ma
us=F/N
I really have no idea how to do Part B, but I tried part A and was real confident with my answer but it turned out wrong. This is what I did.
(2kg)(9.8)=19.6N for the hanging mass
assuming that the Hanging mass = to the tension force on the block with mass m I then did this...
19.6N=m(9.8)cos20*(.8)
m=2.66kg and this is wrong
Were did I go wrong?
Thanks
Welcome to PF!
Part A:
Part B:
Hi charan1! Welcome to PF! :smile:
(Useful tip: don't bother to multiply everything by 9.8 … all the terms have 9.8, so just call it g, and cancel it at the end. :wink:)
(oh … and have a mu: µ :smile:)
I take it you were applying Newton's second law in the direction of the slope.
That means that you must include all the forces … you left out the force due to gravity. :smile:
(For part B, use µK instead of µS)
  • · Replies 19 ·
21K
  • · Replies 18 ·
