Mozart
- 106
I tried to work out this problem a few different ways but I never get the right answer.
A block hangs in equilibrium from a vertical spring. When a second identical block is added, the original block sags by 8.00 cm
What is the oscillation frequency of the two-block system?
What I've done so far:
Attempt 1:
(Fnet)y=-ky
2mg=-ky
m=((-ky)/(2g))
Then using T=2pi times sqaure root[m/k]
puting in my m as what I found in terms of k, y, and g. The K's cancel and I am left with things I know and then calculate to find my T it turns out to be 0.40 seconds
and then I finish off my problem with freqency= 1/period and get 2.5 Hz
But this is incorrect.
I probably made a wrong assumption but I can't put my finger on it. I hope someone can put me on the right track.
Thank you.
Attempt 1:
(Fnet)y=-ky
2mg=-ky
m=((-ky)/(2g))
Thank you.
