Mass suspended from rotating flywheel
In summary, a 0.5kg mass is released from rest and falls a distance of 0.5m in 1.5s while suspended from a 3kg flywheel. The outside radius of the wheel is 300mm and the radius of gyration is 212mm. The linear acceleration of the wheel is 0.444m/s² and the angular acceleration is 1.481 rad/s². The tension in the rope is 4.683N and the frictional torque is 1.205NM.
Andy86
47
A mass of 0.5kg is suspended from a flywheel,
The mass is released from rest and falls a distance of 0.5m in 1.5s
Mass of wheel = 3kg
Outside radius of wheel = 300mm
Radius of gyration = 212mm
a- Linear acceleration of wheel
b- Angular acceleration of wheel
c- Tension in rope
d- Frictional torque
[/B]
a) A = 2 x S / t^2
= 2x 0.5 / 1.5^2
= 0.444m/s
b) Inertia = mass x radius of gyration^2
= 3kg x 0.212^2
= 0.134832 KG M 2
Force = mass x acceleration
= 0.5kg x 0.444
= 0.222N
Torque = Force x Distance
= 0.222N x 0.3
= 0.0666 N
ANGULAR ACCELERATION = TORQUE / INERTIA
= 0.0666N / 0.134832
= 0.4944 Rad / s
c) Tension in rope
tension = Mg - Ma
= (0.5kg x 9.81) - (0.5 x 0.444)
= 4.683N
d) Frictional torque
Torque in rope = force x dist
= 4.683 x 0.3m
= 1.4049NM
Frictional Torque = Torque - Accel. Torque
= 1.4049 - ?
Im not too sure how to find the acceleration torque! I solved these questions (or thought I did a while ago and now I am writing up my solutions to submit them some bits don't make sense, any advice or guidance would be greatly appreciated)
Thanks
A
Hi Andy, welcome to PF :smile: !
How do you distinguish friction from inertia ?
There is nothing on friction in the problem statement.
There is no question in the problem statement.
Is the radius of gyration a given or did you round off ##0.3\sqrt{1\over 2}## ?
Hi BvU, thanks for the warm welcome!
The Radius of gyration is given in question = 212mm or 0.212m
The last question (d) asks to calculate frictional torque (resisting motion)
Mass of wheel = 3kg
c- Tension in rope
[/B]
a) A = 2 x S / t^2
= 2x 0.5 / 1.5^2
= 0.444m/s
These are the wrong units for acceleration.
= 3kg x 0.212^2
= 0.134832 KG M 2
= 0.5kg x 0.444
= 0.222N
= 0.222N x 0.3
= 0.0666 N
These are the wrong units for torque. Remember, the number 0.3 has units.
= 0.4944 Rad / s
These are the wrong units for angular acceleration.
c) Tension in rope
tension = Mg - Ma
= 4.683N
= 4.683 x 0.3m
= 1.4049NM
= 1.4049 - ?
Thanks
A
Ok, got it.
A picture is nice, I suppose you made one ?
Acceleration of the 0.5 kg weight is due to the net force on the thing. one force is mg, the other T (tension in wire)
So reconsider the torque on the wheel/motor assembly.
Next: you don't know the inertia of wheel/motor assembly, so you'll have to find the angular acceleration in a different way.
[edit] have to run now. good luck
Think ill retype this; sorry guys
a) A=2xS/t²
= 2x0.5/1.5²
=0.444 m/s²
b) a = acceleration / radius
= 0.444m/s² / 0.3m
= 1.481 rad/s²
c) tension = Mg - Ma
= (0.5kg x 9.81m/s²) - (0.5kg x 0.444m/s²)
= 4.683N
d) Calculate frictional torque
torque in rope = force x radius
= 4.683N x 0.3M
= 1.4049NM
acceleration torque = Mass x radius of gyration² x angular acceleration
= 3 x 0.212² x 1.481
= 0.199NM
Frictional torque = torque in rope - acceleration torque
= 1.4049 - 0.199
= 1.205NM
Related to Mass suspended from rotating flywheel
1. How does the mass suspended from a rotating flywheel affect its rotational speed?
The mass suspended from a rotating flywheel adds to the total moment of inertia of the system, making it harder for the flywheel to rotate. This results in a decrease in the rotational speed of the flywheel.
2. What is the relationship between the mass of the suspended object and the rotational speed of the flywheel?
The rotational speed of the flywheel is inversely proportional to the mass of the suspended object. This means that as the mass of the object increases, the rotational speed of the flywheel decreases.
3. Can the mass suspended from a rotating flywheel affect the stability of the system?
Yes, the mass suspended from a rotating flywheel can affect the stability of the system. The added mass can cause the flywheel to wobble or vibrate, which can lead to instability and potential system failure.
4. Does the position of the suspended mass on the flywheel affect its rotational speed?
Yes, the position of the suspended mass on the flywheel can affect its rotational speed. The closer the mass is to the center of the flywheel, the less effect it will have on the rotational speed. Conversely, a mass placed farther away from the center will have a greater effect on the rotational speed.
5. How does the mass suspended from a rotating flywheel affect the energy required to rotate the flywheel?
The mass suspended from a rotating flywheel increases the total moment of inertia, which means more energy is required to rotate the flywheel. This results in a decrease in the efficiency of the system and potentially higher energy costs.
  • Mechanical Engineering
