Lides2011
- 1
The lab that we did measured mass vs. weight. We took eight objects and found that mass using the triple beam balance (units in Kg) and the found the weight using a spring scale (units in Newtons)
Assume that this experiement had been performed on the moon istead on on Earth. Decide which of the following quantities would have the same values and which would be different. Discuss either why that quantity would not change, or if it would chamge, how it would be different and why?
The mass of each object:
The weight of each object:
The slope of the weight vs. mass graph:
Theequation relating mass and weight:
The mass: I said the mass would change because a triple beam balance relies on gravity, therefore, it would not work on the moon.
The weight: it would not change bc it does not rely on gravity
The slope of the weight vs. mass graph: I calculated the slope to be 11.43 using two points on my graph, and I think it would chamge because the mass would change, as I said above.
The equation relating mass and weight: My equation was y=11.43x there was no y intercept because we started the line at the origin. So I think the equation would change because the slope would change.
Thank you!
Thank you!
