Mass x Velocity prototype problem
However, it is important for the inventor to consider all factors and gather all necessary data in order to determine the parameters for their prototype.
drewman13
Independent non-engineer inventor is looking to determine parameters for prototype.
Compressing a piston using rolling weights.​
Need to know if a weight (wheel) is doubled in mass does that reduce the velocity loss (as a result of rolling over and compressing the piston) by one half? Assuming the initial velocity is the same for both weights.
Current prototype question:
A 10 lbs.weight (wheel) 6 inches from the axle held within a circular steel frame traveling at 7,200 rpm (282 fps = to 88,385 lbs. of centrifugal force) if that wheel ran over and compressed a perimeter-placed piston 1/4” at 366 lbs. of pressure (91 inch lbs. of total force), what would be the loss of velocity?
This is not a homework question-I am an inventor who, unfortunately, holds a communications degree.
Unfortunately, this question cannot be answered without further information. In order to calculate the velocity loss, we need to know the coefficient of friction between the wheel and the piston, as well as the frictional force and torque applied on the wheel. Without this additional information, it is impossible to determine the velocity loss.
Related to Mass x Velocity prototype problem
What is the "Mass x Velocity prototype problem"?
The "Mass x Velocity prototype problem" is a hypothetical scientific problem used to demonstrate the relationship between mass and velocity in the context of physics. It involves calculating the momentum of an object by multiplying its mass (in kilograms) by its velocity (in meters per second).
Why is the "Mass x Velocity prototype problem" important?
The "Mass x Velocity prototype problem" is important because it helps us understand the concept of momentum, which is a fundamental property of moving objects. It also shows how mass and velocity are directly proportional to each other in determining an object's momentum.
How do you solve the "Mass x Velocity prototype problem"?
To solve the "Mass x Velocity prototype problem", you simply need to multiply the mass of the object (in kilograms) by its velocity (in meters per second). The resulting value will be the object's momentum, measured in kilogram-meters per second (kg*m/s).
What are some real-world applications of the "Mass x Velocity prototype problem"?
The "Mass x Velocity prototype problem" has many real-world applications, such as calculating the force needed to move a certain object, determining the impact of a moving object, and understanding the behavior of objects in motion, such as in collisions or explosions.
What is the difference between mass and velocity in the "Mass x Velocity prototype problem"?
In the "Mass x Velocity prototype problem", mass refers to the amount of matter an object contains, while velocity is the measure of an object's speed and direction of motion. Both mass and velocity are important factors in determining an object's momentum.
  • Mechanical Engineering
