Masses Moving Radially on a Rotating Disk
In summary, the fifth object will slide off the disk if it moves faster than the maximum angular speed of 4.43 rad/s.
hquang001
31
Four objects (each mass m=60 kg) are attached to a disk, which has a radius of r= 1.5 m and a moment of Inertia of I=130 kg m2. The objects can be moved by a motor from an outer position (ro=1.5 m) to an inner position (ri= 0.3 m). A fifth object (mass m5=60kg) is placed onto the disc. This object is not fixed to the disc like the other ones. But it has an unbelievable high static friction coefficient with the disc of μs=3.0. The kinetic friction coefficient has a value of μk=0.9. The disc starts to rotate at a modest 20 rev/min. All objects are at their outer positions. Then suddenly the motor moves the four objects to the inner positions. What is happening to the fifth object? Explain why and prove it by calculation. Keep in mind that g=9.81 m/s2
I1 w1 = I2 w2
F = ma
m = 60kg, ω0 = 2.094 rad/s, I of disk = 130 kgm^2 , outer position ro = 1.5m, inner position ri = 0.3m
∴Fifth object :
Ffriction = m.ac
μ.m.g = m. v^2 / R
=> v
max = √ 3. (1.5m) . (9.81 m/s^2 ) = 6.64 m/s => ωmax = 4.43 rad/s
so when the fifth object move with greater speed than vmax =6.64m/s , it will slide off
When four objects are moved to inner position, due to conservation of angular momentum, the final angular velocity of the disk will increase. and if it exceed the maximum angular speed, it slides off
Using conservation of angular momentum:I1ω1 = I2ω2
(130 + 5.m.r0^2). (2.094 rad/s ) = (130 + 4.m.ri^2 + m.x^2) .ω2
I got stuck here. I can't find final angular velocity and therefore can't find the position of the fifth object
Assume it stays in place at ro and see if that leads to a problem or not.
Likes hquang001
Assume fifth object stay at ro :
=> w2 = 5.88 rad/s
it exceeds the maximum and will slide off but the position of the object is 1.5m, so is it wrong ?
So it will slide off.
And that answers the question of the exercise.
Likes hquang001
Ohh i got it
Thank you
This is a strange question.
We are told the motor suddenly moves the four blocks to a smaller radius. That would generate a large acceleration of the disk, and the tangential acceleration surely would defeat the static friction anyway.
That in itself would not jettison the mass; it would simply find itself a bit further round the disk. So whether it then stays on the disk depends on the kinetic friction, which we are given.
Seems to me that the question setter has made a mistake, not having intended that the new radial acceleration alone would be enough to overcome static friction.
Likes Lnewqban and hquang001
When I re-read the probem statement, the fifth object starting at the outer position has no chance to move further round the disk !
I don't think the exercise composer intended anything more complicated than ##\ m\omega^2/r_o > f_s\,N ##
Likes hquang001
Just allow a small margin between the object and the very edge of the disk. A sudden increase in spin would mean that the initial trajectory of the object relative to the disk is tangential. Only after that slippage starts, robbing the object of most of its frictional force, will it slide radially.
The two suspicious facts are
  • The movement of the other blocks is described as sudden
  • We are given a much lower kinetic friction coefficient
Why do either of those if they are irrelevant?
I see,
Can I make a case that the slippage occurs instantaneously ?
So the block no longer contributes to the moment of inertia - meaning ##\omega## steps from 2.094 not to 5.883 but to 11.12 rad/s
Kinetic friction is enough to maintain circular trajectory up to ##\omega ## = 2.43 rad/s which takes about 0.04 s.
That would mean: even without margin the object would do about 5 degrees on the rim and then continue in a straight line ? I think this is one of those exercises that hasn't been thought through completely by the composer; average to good students have no problem but very good students run into time-wasting complications.
Likes Lnewqban
FAQ: Masses Moving Radially on a Rotating Disk
What is the concept of "Masses Moving Radially on a Rotating Disk"?
The concept of "Masses Moving Radially on a Rotating Disk" refers to a scenario in which objects are placed on a disk that is rotating around a central axis. The objects are then allowed to move freely along the radius of the disk, due to the centrifugal force generated by the rotation.
What is the Coriolis effect and how does it relate to "Masses Moving Radially on a Rotating Disk"?
The Coriolis effect is the apparent deflection of an object's path due to the rotation of the Earth. In the context of "Masses Moving Radially on a Rotating Disk", the Coriolis effect causes the objects to follow a curved path instead of a straight line, as seen from the rotating frame of reference.
How does the speed of rotation affect the movement of masses on a rotating disk?
The speed of rotation has a direct impact on the movement of masses on a rotating disk. As the speed of rotation increases, the centrifugal force also increases, causing the objects to move farther away from the center of the disk. At a certain critical speed, the objects will experience a loss of contact with the disk and will start to fly off tangentially.
What is the difference between the movement of masses on a rotating disk and a stationary disk?
The main difference between the movement of masses on a rotating disk and a stationary disk is the presence of a centrifugal force. In a stationary disk, the objects will remain at rest unless acted upon by an external force. However, in a rotating disk, the objects will experience a centrifugal force that causes them to move radially away from the center.
How does the placement of masses on a rotating disk affect their movement?
The placement of masses on a rotating disk can affect their movement in several ways. If the masses are placed closer to the center of the disk, they will experience a weaker centrifugal force and will move at a slower speed. On the other hand, if the masses are placed farther from the center, they will experience a stronger centrifugal force and will move at a faster speed.
