- 24,492
- 15,025
Does anyone here know a source, where the equation of motion for a massless charged particle (which of course does not exist in Nature as far as we know) in a homogeneous electric field is actually solved? I googled, and there are some papers about this, but the equations are never actually solved, although they are pretty easy.
My idea was to use the action principle in a covariant formulation with a Lagrange multiplyer to enforce the mass-shell condition for a massless particle, as follows. To that purpose I take the Lagrangian to read
[tex]L=-\lambda \dot{x}_{\mu} \dot{x}^{\mu} +q x^3 E \dot{x}^0,[/tex]
where the metric is [itex]\eta_{\mu \nu}=\text{diag}(1,-1,-1,-1)[/itex] and the speed of light is set to 1.
In order to lead to a scalar action, the Lagrange multiplier must transform under reparametrizations of the "world-time parameter", [itex]\tau[/itex] (which is NOT the proper time of the particle, because we cannot define the proper time for a massless particle) as
[tex]\tau \rightarrow \tau', \quad \lambda \rightarrow \lambda'=\lambda \frac{\mathrm{d} \tau'}{\mathrm{d} \tau}.[/tex]
Thus, after deriving the equations of motion from the action principle, I can choose the "world-time parameter" such that [itex]\lambda=\text{const.}[/itex].
Then the equations of motion read like for a massive particle
[tex]\lambda \ddot{x}^0=q E \dot{x}^3, \quad \dot{\vec{x}}=q \dot{x}^0 E\vec{e}_3,[/tex]
and the constraint
[tex]\frac{\mathrm{d} x^{\mu}}{\mathrm{d} \tau} \frac{\mathrm{d} x_{\mu}}{\mathrm{d} \tau} =0.[/tex]
Solving this set of equations for the initial conditions that [itex]\dot{\vec{x}}(0)=u_0^1 \vec{e}_1[/itex]
leads to the solution
[tex]x^1=u_0^1 \tau, \quad x^2=0, \quad x^3=\frac{u_0^1}{\omega} \left [\cosh(\omega \tau)-1 \right ], \quad t=x^0=\frac{u_0^1}{\omega} \sinh(\omega \tau),[/tex]
where
[tex]\omega=\frac{q E}{\lambda}.[/tex]
Now, I don't know, how to get rid of the arbitrary Lagrange parameter [itex]\lambda[/itex], which has the dimension of mass (or energy). The problem is that, even when I try to eliminate the arbitrary "world-time parameter" [itex]\tau[/itex] with the coordinate time, [itex]t[/itex], the dependence on the arbitrary Lagrange parameter doesn't vanish, and I don't see any other equation to fix it to some physically interpretable quantity.
So my question is: Can I conclude that a classical massless charged particle in a electrstatic homogeneous field doesn't make sense or is there some way to fix [itex]\lambda[/itex] by physical quantities?
and the constraint
where
