Mastering PDEs: Techniques and Tricks for Solving with Separation of Variables
  • Thread starter spaghetti3451
  • Tags
    Pde
In summary, the technique of separation of variables can be used to solve partial differential equations, but it only provides a general solution when the PDE is linear. In order to find a non-trivial solution, the boundary conditions must be satisfied and the initial conditions can be satisfied by combining the solutions for all integer values of k using the "Fourier series" solution.
spaghetti3451
1,344
34
To solve a PDE, we can use the technique of separation of variables. However, this is not the most general solution.
But, the mathematical trick is that we can solve for the SoV solutions and then make a general solution by adding SoV solutions together. I don't understand what this means?
That's only true if the pde is linear.
Consider the equation
[tex]U_{xx}= U_{tt}[/tex]
with boundary conditions U(0, t)= 0 and U(L, t)= 0 and initial conditions U(x, 0)= f(x), Ut(x, 0)= 0.
If U(x,t) and V(x,t) are two functions satisfying that equation and a and b are any two numbers, then [itex](aU+ bV)_{xx}= aU_{xx}+ bV_{xx}[/itex] and because U and V satisfy [itex]U_{xx}= U_{tt}[/itex] and [itex]V_{xx}= V_{tt}[/itex], we can write that as [itex]aU_{tt}+ bV_{tt}= (aU+ bV)_{tt}[/itex] so that [itex](aU+ bV)_{xx}= (aU+ bV)_{tt}[/itex]. That is, aU+ bV satisfies the same differential equation.
If we let U= T(t)X(x) (separate it into a function of t only and a function of x only) we get
[tex]TX''= T''X[/tex]
which we can rewrite as
[tex]\frac{X''}{X}= \frac{T''}{T}[/tex]
Since the left side depends only upon x and the right depends only on t, in order to be equal for all x and t, the two sides must be equal to the same constant.
That is,
[tex]\frac{X''}{X}= \frac{T''}{T}= \lambda[/tex]
for some constant [itex]\lambda[/itex].
That gives us the two equations [itex]X''= \lambda X[/itex] and [itex]T''= \lambda T[/itex].
Further, U(0, t)= X(0)T(t)= 0. Either T(t)= 0 which would mean U(x, t)= 0 for all x and t, or X(0)= 0. In order that this problem have a non-trivial solution, we must have X(0)= 0. Also U(L, t)= X(L)T(t)= 0 gives X(L)= 0.
To solve [itex]X''(0)= \lambda[/itex] with boundary conditions X(0)= 0, X(L)= 0, consider possible values for [itex]\lambda[/itex]
1) If [itex]\lambda= 0[/itex], we have [itex]X''= 0[/itex] which has general solution X(x)= Ax+ B. Then X(0)= B= 0 and X(L)= AL+ 0= 0 so A= 0. X must be identically 0 which means U must be identically 0 which means we cannot match the initial conditions.
2) If [itex]\lambda> 0[/itex], we can write [itex]\lambda= \alpha^2[/itex] with [itex]\alpha\ne 0[/itex]. Now the equation is [itex]X''= \alpha^2X[/itex] which has general solution
[tex]X(x)= Ce^{\alpha x}+ De^{-\alpha x}[/tex]
[tex]X(0)= C+ D= 0[/tex]
[tex]X(L)= Ce^{\alpha L}+ De^{-\alpha L}= 0[/tex]
From the first equation, D= -C so the second equation becomes
[tex]Ce^{\alpha L}- Ce^{-\alpha L}= C(e^{\alpha L}- e^{-\alpha L})= 0[/tex]
But one of those exponentials is greater than 1 while the other is less than 1. The difference cannot be 0 which means we must have C= 0 and then D= 0. Again, that is the trivial solution which we cannot use.
If [itex]\lambda< 0[/itex], we can write [itex]\lambda= -\alphaa^2[/itex] with [itex]\alpha\ne 0[/itex]. Now the differential equation for X is [itex]X''= -\alpha^2X[/itex] which has general solution
[tex]X(x)= C cos(\alpha x)+ D sin(\alpha x)[/tex]
[tex]X(0)= C= 0[/tex]
[tex]X(L)= D sin(\alpha L)[/tex]
The only way to avoid D= 0 and another trivial solution is to have [itex]sin(\alpha L)= 0[/itex] which means [itex]\alpha L[/itex] must be a multiple of [itex]\pi[/itex]: [itex]\alpha L= k\pi[/itex] so [itex]\alpha= k\pi/L[/itex] for integer k.
But then
[tex]X(x)= C sin((k\pi/L)x)[/tex]
satisfies the differential equation
[tex]X''= -(k\pi/L)^2X[/tex]
and the boundary condition X(0)= 0, X(L)= 0 for any C or integer k.
Now that we know [itex]\lambda= -\alpha^2= -(k\pi/L)^2[/itex] we can write the differential equation of T as
[tex]T''(t)= -(k\pi/L)^2T(t)[/tex]
which also has general solution
[tex]T(t)= Acos((k\pi/L)t)+ B sin((k\pi/L)t)[/tex]
Now, one of the intial conditions is [itex]U_t(x, 0)= X(x)T'(0)= 0[/itex] which means that we must have
[tex]T'(0)= -A(k\pi/L)sin((k\pi/L)0)+ B(k\pi/L)cos((k\pi/L)0)= B(k\pi/L)= 0[/tex]
so B= 0.
But the other intial condition, [itex]U(x, 0)= f(x)[/itex] cannot be separated in that way.
What we have so far is
[tex]U(x,t)= X(x)T(t)= AC sin((k\pi/L)x)cos((k\pi/L)t)[/tex]
and so
[tex]U(x, 0)= C' sin((k\pi/L)x)= f(x)[/tex]
where I have written C' for AC.
Now for some functions, f(x), that can easily be done- if [itex]f(x)= 4sin((3\pi/P)x)[/itex] it is easy to see that we can set C'= 4 and k= 3 to get
[tex]U(x, t)= 4sin((3\pi/L)x)cos((3\pi/L)t)[/tex]
But what if f(x) were some more complicated function? Say, f(x)= x(L- x) (chosen so that f(0)= 0, f(L)= 0)? Because, as I showed above, sums of solutions to the equation also satisfy the equation, what we can do in that case is combine the solutions for all integer values of k:
[itex]U(x, t)= \sum_{k=0}^\infty C_ksin((k\pi/L)x)cos((k\pi/L)t)[/itex]
and try to find [itex]C_k[/itex] such that
[itex]U(x, 0)= \sum_{k=0}^\infty C_k sin((k\pi/L)x)= x(L- x)[/itex]
That is precisely the "Fourier series" solution.
FAQ: Mastering PDEs: Techniques and Tricks for Solving with Separation of Variables
What is "Mastering PDEs: Techniques and Tricks for Solving with Separation of Variables" about?
"Mastering PDEs: Techniques and Tricks for Solving with Separation of Variables" is a book that focuses on teaching the techniques and tricks for solving partial differential equations (PDEs) using the method of separation of variables. This method involves breaking down a PDE into simpler, ordinary differential equations (ODEs) to find a solution.
Who is the target audience for this book?
The target audience for this book is anyone interested in learning how to solve PDEs using separation of variables. This includes students, researchers, and professionals in the fields of mathematics, physics, engineering, and other related disciplines.
What are some of the key topics covered in this book?
Some of the key topics covered in this book include: basic concepts of PDEs, techniques for solving PDEs using separation of variables, applications of separation of variables in different fields, and advanced topics such as Sturm-Liouville theory and Fourier series.
Do I need any prior knowledge in PDEs to understand this book?
While some background knowledge in PDEs and ODEs can be helpful, this book is designed to be accessible to readers with a basic understanding of calculus and linear algebra. The book starts with an introduction to PDEs and gradually builds up to more advanced topics, making it suitable for both beginners and those with some prior knowledge in the subject.
How can this book benefit me as a scientist?
As a scientist, this book can benefit you by providing a comprehensive guide to solving PDEs using separation of variables. This method is widely used in many fields of science and engineering, making it a valuable tool for solving real-world problems. Additionally, the book includes various examples and exercises to help you practice and apply the techniques in your own research or work.
