Mastering Physics Help, Conservation of Momentum
In summary, a 238U nucleus decays into an alpha particle and a 234Th nucleus. Using conservation of momentum, the speed of the thorium nucleus is calculated to be 3.30*10^5 m/s in the negative y direction. The direction of motion of the thorium nucleus is found to be 47 degrees below the x-axis.
theoblivin8r
A 238U nucleus is moving in the x direction at 4.5*10^5 m/s when it decays into an alpha particle 4He and a 234Th nucleus.
1.) If the alpha particle moves off at 34degrees above the x-axis with a speed of 2.0*10^7 m/s, what is the speed of the thorium nucleus?
2.)What is the direction of the motion of the thorium nucleus?
I know that momentum is conserved since this is a totally inelastic collision in reverse.
M1(V1)+M2(V2)=(M1+M2)VFinal
1.)Im using the atomic numbers for the masses.
238(4.5*10^5)=4(2.0*10^7m/s)+234(V2)
Solving for V2 I got the answer 1.158*10^5 or 1.2*10^5. Mastering physics says this is wrong and nothing else. I believe I might have the wrong formula or something.
2.) I have no ideo how to start this part of the problem. Any help/tips would be greatly appreciated
Since momentum is a vector, apply conservation of momentum to each component (x and y) separately.
Okay, I understand that I need to look at the conservation of momentum for both the x and y directions. Here was my next attempt.
M1(V1x)+M2(V2x)=(M1+M2)Vfinal(x)
M1(V1y)+M2(V2y)=(M1+M2)Vfinal(y)
Using the angle 34 as given I calculated the initial velocities of the 4He particle.
2.0*10^7(sin34)=V1x=1.12*10^7
2.0*10^7(cos34)=V2y=1.66*10^7
I substituted those values into the equations above again using the atomic number as the masses.
4(1.12*10^7m/s)+234(V2x)=238(4.5*10^5m/s) Solving for V2x I got 2.66*10^5
4(1.66*10^7m/s)+234(V2y)=238(4.5*10^5m/s) Solving for V2y I got 1.74*10^5
Next I used the Pythagorean Theorem to calculate the final velocity using the x and y components. (2.66*10^5)^2+(1.74*10^5)^2=Vfinal^2
Solving for Vfinal I got 3.18*10^5
This is still wrong according to mastering physics and I received no feedback from the program on how it was wrong. Any help again would be greatly appreciated.
If my math doesn't fail me velocity in x direction should be vcos34 and vsin34 for y direction.
Initially the particle is moving in the x direction so second equation is wrong the particle has no velocity in the y direction.
Okay, this makes sense if you are talking about the 238U particle. I see my simple error in calculating the x-velocity. Here was my next attempt.
V1x=2.0*10^7(cos34)=1.66*10^7m/s
V1y=2.0*10^7(sin34)=1.12*10^7m/s
Since there is no velocity in the y direction for the initial particle I revised my formula.
M1(V1y)+M2(V2y)=(M1+M2)VFinal(y)
M1(V1y)+M2(V2y)=0
M1(V1y)=-M2(V2y)
4(1.12*10^7m/s)=-234(V2y) Solving for V2y I got -1.91*10^5m/s. This negative sign indicates the particle is moving in the negative y direction.
So again using the Pythagorean Theorem I calculated the final velocity of the 234Th particle.
(2.66*10^5m/s)^2+(-1.91*10^5)^2=(V2Final)^2 Solving for V2Final I got 3.30*10^5m/s.
I submitted it into Mastering Physics and again it was wrong with no feedback. I'm getting a little concerned because I only have one more attempt to get the answer right. Again any help/tips will be greatly appreciated.
By the way I have to go to work so I'll check back in around 6 hours. Thanks again.
Dude, work it out again i see velocity in x direction 2.66 which is the same in the previous post.
Sorry, In my rush to complete the problem I got ahead of myself and forgot to correct my previous mistake.
Well I fixed my error and found the new V1x and used it to calculate the V2y. Then I used the Pythagorean Theorem and found a velocity of 2.6*10^5 and it was correct.
Now onto the second part of the question.
2.) What is the direction of the motion of the thorium nucleus?
This part was simple. I drew a right triangle and placed the velocities on their corresponding sides. I used sin(theta)=(-1.9*10^5m/s)/(2.6*10^5m/s) and took the inverse sin of that answer to get a angle of 47 degrees which was correct.
Thanks for the help people.
FAQ: Mastering Physics Help, Conservation of Momentum
What is conservation of momentum?
Conservation of momentum is a fundamental law of physics that states that the total momentum of a closed system remains constant over time. This means that in a closed system, the total amount of momentum before and after an event must be the same.
How is momentum calculated?
Momentum is calculated by multiplying an object's mass by its velocity. The formula for momentum is p = m x v, where p is momentum, m is mass, and v is velocity. Momentum is typically measured in units of kilogram-meters per second (kg*m/s).
How does conservation of momentum apply to collisions?
In a collision between two objects, the total momentum before the collision must be equal to the total momentum after the collision. This means that the sum of the momenta of the two objects remains constant, even if they change direction or speed during the collision.
Can you give an example of conservation of momentum in real life?
One example of conservation of momentum in real life is a rocket launch. As the rocket propels itself upwards, it exerts a force on the ground and the ground exerts an equal and opposite force on the rocket, resulting in a change in momentum. However, the total momentum of the rocket and the Earth remains constant.
How can mastering physics help with understanding conservation of momentum?
Mastering physics can help by providing interactive simulations and practice problems that allow students to apply the principles of conservation of momentum. It also provides instant feedback and step-by-step solutions, allowing students to track their progress and identify areas for improvement.
