Courses Masters in Civil Engineering with a Bachelor in general engineering
The discussion centers on the challenges faced by a student pursuing a bachelor's degree in General Engineering who aims to transition into a master's program in civil engineering. The student seeks advice on which online civil engineering courses to take, given their university does not offer them. There is skepticism about the value of a General Engineering degree compared to traditional engineering degrees, with concerns that it may not adequately prepare the student for engineering roles. Key recommendations include taking essential civil engineering courses such as reinforced concrete design, structural analysis, and environmental engineering, as well as ensuring that any online courses are accepted for master's program admission. It is emphasized that the student should verify the specific foundational courses required for eligibility and consider the importance of lab work and in-person attendance for a comprehensive education.
abdelgo
Hello,
I'm currently pursuing my bachelor's degree in General Engineering. My goal is to do my master's degree in civil engineering. Therefore, my thematic area should be in civil engineering. However, my university does not offer classes in civil engineering, so I need to take them online.
I have attached my program flowchart to this thread. It lists all the classes I have taken and will take. Based on this flowchart, please suggest the classes I need to take to be eligible for my master's program without having to take any undergraduate courses
Honestly this is the first time I ever heard of a Bachelor's Degree in General Engineering. Typically, it's a BS in Civil, Mechanical, or Electrical Engineering, or BS in Civil, Mechanical, or Electrical Engineering Technology (which is good, but it is less intensive and a not as good option). This BSGE may be helpful for a drafting job or some lower position than Engineer in an Engineering firm, but to me it's useless for an engineering job. So yes, you need to take Civil Engineering courses , but on-line does not always fly, ideally you should attend a college for perhaps 2 years. You would need courses like reinforced concrete design, structural steel design, environmental engineering, structural analysis, advanced mechanics of materials, soils, foundation design, and more, including lab work.
Likes DeBangis21, abdelgo, gwnorth and 1 other person
This appears to be an interdisciplinary type of build your own degree maybe somewhat akin to Systems Engineering or Industrial Engineering or basically a program that applies an Engineering pedagogy framework and you direct it based on your choice of electives. So depending on which courses you opt for for your 3rd and 4th year technical electives it may be possible that you would be qualified to apply to a civil engineering master's program but you would need to research to make sure you took all the necessary foundational courses required for admission. You would also need to check to see if online courses would be acceptable for admission.
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
