franceboy
- 51
hi there,
i am from France, so excuse my mistakes languagewise, please.
We got some long-time tasks in physics because our teacher is away. One of them is really hard. I hope you can help me a little bit.
Match the following graph to one of these experiments.
Since the graph is very small and you can not see it on computer really well, i have wrote the look-up table of the graph.
exp1: The collision of a small ball on a planar table which is located 20 cm over the ground.
y is the height of the ball in cm and x is the time after the collision in ms.
exp2: A capacitor with the capacity of 6.8 μF is charged with a resistance of 3.3 MΩ. At the beginning he has a voltage of 20V. y is the voltage in V and x is the time in s.
exp3: 100 ml water are heated electrically with the power of 350 W. The water has the temperature of 20°C at the beginning. y is the temperature in °C and x the time in s.
Ok now my ideas:
exp1: The ball is small and has a low velocity so that we can neglect the air resistance. Then the formula is h(t)= 0.2m + v*t + 1/2*g*t^2, and v is the start velocity of translation in the direction of y. We can determine v from the table: v≈ 7 m/s. I have calculated some values but after 80 ms they differ a lot from the ones of the table. So i thaught that exp1 is wrong.
exp2: The formula is U(t)= 20V+(U-20V)*(1-e^(-t/(R*C))) with U as maximal voltage. The slope in the start point would be U´(0)= 1/(R*C)*(U-20V)≈ 0.7 V/s. The value 0.7 V/s was determined with the table. But than U would be lower than 40V which is wrong.
exp3: My strategy is to use the energys:
Q= m*c*ΔT= 350W*t. However T(t) is a linear function then which differs from the values.
Consequently every experiment would be false but our teacher said that one of them is wright!
THANK YOU in advance![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Ok now my ideas:
