Matching couples at a party (mean and variance)
  • Thread starter Master1022
  • Tags
    Variance
In summary: Next, I calculated the expected value for each of the three possible outcomes.Finally, I calculated the mean and variance for the total number of couples that are paired together, by taking the expected value of the three outcomes combined.
Master1022
611
117
At a party there are ##n## couples. When the last song comes on, each person randomly picks a dance partner. What is the: (a) mean, (b) variance of the number of couples that are paired together?
Expected value
Variance
Hi,
I was attempting the following problem and I didn’t know how to start it off correctly.
Question: At a party there are ##n## couples. When the last song comes on, each person randomly picks a dance partner. What is the: (a) mean, (b) variance of the number of couples that are paired together?
Attempt:
For (a), I was thinking of using some indicator variables ##X_i## for ##i \in {1,2,…,n}## where ##X_i = 1## when couple ##i ## is actually paired up with one another, and the variable equals 0 otherwise. Thus, we have:
$$ \text{number of couples actually paired up} = Z = X_1 + X_2 + … + X_n $$
Thus, we can get the expected value ##E(Z)## by using the linearity of expectation:
$$ E(Z) = E(X_1 + X_2 + … + X_n) = \sum_{i = 1}^{n} E(X_i) $$
where ## E(X_i) = P(X_i = 1) ##. To get this probability, all I could currently think of is: ##P(X_i = 1) = 1 \cdot \frac{1}{2n - 1} = \frac{1}{2n - 1} ##
and thus I get ## E(Z) = \frac{n}{2n - 1} ##, which doesn’t really seem correct from an algebraic point of view.
Where have I gone wrong? [EDIT: I am guessing I have gone wrong in finding the probability or the general method]
Any help would be greatly appreciated.
Likes Delta2
Easy cases
for n=1 couples
expectation value = 1
sigma = 0
for n=2 couples
2 couples : 2 cases
1 couple : (2C1)^2 (2-1)^2= 4 cases
All the vote = 2^4=16
expectation value = (2*2+1*4+0*12)/16=0.5
sigma = ##\sqrt{2(2-0.5)^2+4(1-0.5)^2+12(0-0.5)^2}##
You may go this way to higher n.
anuttarasammyak said:
Easy cases
for n=2 couples
2 couples : 2 cases
This doesn't look right. For ##n =2## I get a mean of ##\frac 2 3##. As ##p(0) = \frac 2 3## and ##p(2) = \frac 1 3##. Note that ##p(1)=0##.
I'm not sure how to calculate these quantities for general ##n##. I suspect it's not easy.
There is a quick way to calculate the mean. I'm not sure how to get the variance.
Easy cases
for n=1 couples
sigma = 0
for n=2 couples
2 couples : 2 cases
Ya, I was wrong.
For n=2
1 couple : 2C1 ^2 (2^2-1)=12
0 couple: 2 cases
Expectation value = 1
Sigma=0.5
I hope it is right.
Ya, I was wrong.
For n=2
0 couple: 2 cases
Sigma=0.5
I hope it is right.
That's not right. I've posted the correct probabilities in post #3.
There's also a simple way to get a general expression for the mean for ##n## couples.
I can't see a way to get the variance for general ##n##.
Ya, I was wrong.
For n=2
0 couple: 2 cases
Sigma=0.5
I hope it is right.
Ah, okay, assuming each couple is one of each sex etc. I was assuming anyone could be paired with anyone else. That changes things.
The problem simplifies with the interpretation of @anuttarasammyak.
The mean should be easy and I have a recursive inductive proof for the variance. It's not that simple, but not too complicated either.
If you refer to a person matched with their original partner, the count is given by the number of Edit: @PeroK Derangements. As n grows, the proportion approaches 1/e.
  • Skeptical
Likes Master1022 and PeroK
I interpreted it in my old standard. The standard might have been changed.
You were right. I initially assumed anyone could be paired with anyone else, but I'm sure that's wrong.
There's a neat solution.
Hi, sorry for late replies. Thanks @PeroK , @anuttarasammyak , and @WWGD for the replies. I did a bit of reading around earlier today and also came across the mention of 'derangements' (as mentioned by @WWGD). I'll have a bit more of a look into that to see whether I can make any progress and then post back here with my updates.
@PeroK : in post #12, did you suggest that the above solution methods in the thread were correct, or are they still wrong (due to different interpretation based on my unclear wording)?
It's definitely the case that if you have two couples ##A_1, A_2, B_1, B_2##, then ##A_1## may only be paired with either ##A_2## or ##B_2##. And ##A_1## cannot be paired with ##B_1##.
Here's how I approached the probl;em.
First, I calculated the probabilities, mean and variance for ##n = 2, 3## and ##4##. The pattern was obvious, so it was a question of proving it.
The mean was easy. Think about repeating the experiment many times and the relationship between a single couple being paired together and the expected number of couples being paired together each time.
The variance, as I said, was trickier. Then I had an idea that I might be able to relate ##p_{n+1}(k+1)## to ##p_n(k)## - where this is the probability of ##k## couples out of ##n## being paired together. I looked at the data for ##n = 2, 3, 4## and spotted the relationship. I then proved it.
Using this, I was able to relate the variance for ##n+1## to the expectation for ##n##. And, this gave me the inductive step.
I hope that makes sense.
I suppose another interpretation of the problem is stated as :
There are 2n pupils in the class. Teacher said they should be paired for some class work. Calculate p(m), probability of m pairs matched after the first vote of with whom they want to make a pair.
In order to make it mathematical ideal, the teacher give 1 to 2n number cards to the pupils. They know only their own number and should vote a number of not their own.
First easy cases
For n=1
1pair : 1 case
e.v.=1, sigma=0
For n=2
2 pairs : 3 cases
1 pair : 4C2 *(3^2-1)= 48 cases
0 pair : 3^4-3-48=30 cases
e.v. = 54/81=2/3=0.667
sigma = ##\sqrt{96/(81*9)}=0.363##
[EDIT]
Some class consists of odd number pupils. For class of 3 pupils
1 pair : 6 vote cases
0 pair : 2 vote cases
p(0)=1/4, p(1)=3/4=e.v., sigma=3/8
FAQ: Matching couples at a party (mean and variance)
How do you calculate the mean and variance for matching couples at a party?
The mean for matching couples at a party can be calculated by dividing the total number of couples by the total number of people at the party. The variance can be calculated by finding the average of the squared differences between the number of couples and the mean.
Why is it important to calculate the mean and variance for matching couples at a party?
Calculating the mean and variance for matching couples at a party can provide insight into the distribution of couples at the party. This information can be useful for event planning and understanding the dynamics of the party.
How does the mean and variance affect the success of matching couples at a party?
The mean and variance can affect the success of matching couples at a party by indicating the likelihood of couples being matched. A higher mean and lower variance may suggest a higher chance of successful matching, while a lower mean and higher variance may indicate a lower chance of successful matching.
Can the mean and variance for matching couples at a party change throughout the event?
Yes, the mean and variance for matching couples at a party can change throughout the event. As more couples arrive or leave, the total number of couples and people at the party will change, thus altering the mean and variance.
How can the mean and variance for matching couples at a party be used to improve future events?
The mean and variance for matching couples at a party can be used to analyze the success of the event and make improvements for future events. For example, if the mean is low and the variance is high, event planners may consider implementing activities or strategies to increase the likelihood of successful matching at future parties.
