Material engineering calculation
In summary, bone in mammals is composed of approximately 70 wt.% of carbonated apatite and 30 wt.% of collagens on a dry weight basis. Using the weight and density of these components, the volume percentages of apatite and collagen can be calculated to be 48.3% and 51.7%, respectively. In vivo, bone contains 20 vol.% of water and 80 vol.% of carbonated apatite and collagens. Using the volume of these components, the volume percentages of apatite and collagen can be calculated to be 38.6% and 41.4%, respectively. It is important to approach this problem without relying on memorized formulas and instead using basic principles of
Andy7199
Water corresponds to approximately 20 vol.% of the bone in mammals. On a dry weight basis, approximately 70 wt.% of the bone is composed of carbonated apatite. The density of apatite is ~3.0 g/cm3. Density of dry collagens is ~ 1.2 g/cm3. Calculate the volume percentages of apatite and collagen in dry bone. Calculate the volume percentages of water, apatite and collagen in bone in vivo.
Vf = (Wf / ρf) / (Wf / ρf + Wm / ρm)
where Vf = Volume fraction, Wf = Weight fraction of filler, Wm = Weight fraction of maxtrix, ρm and ρf = Density of matrix and fiber respectively
[/B]
Regarding the dry bone, it contains 70 wt.% of carbonated apatite and 30 wt% of collagens.
Volume percentages of carbonated apatite:
vf = [(70/3) / (70/3 + 30/1.2)] *100
vf = 48.3 %
Volume percentages of collagens:
vf = [(30/1.2) / (70/3 + 30/1.2)]*100
vf = 51.7 %
Regarding the bone in vivo, it contains 20 vol.% of water and 80 vol% of carbonated apatite and collagens.
vf = 48.3*0.8 = 38.6 %
vf = 51.7*0.8 = 41.4 %
I know this is a standard textbook question but I am really wondering whether I am wrong or not.
Can anybody please give me some opinion? Cause I think it is too simple for this question...Thank you so much.
I would not recommend solving a problem like this using memorized formulas. Try the following and see how it works for you.
Take as a basis 100 gm of dry bone. How many grams of apatite are there? How many grams of dry collagen are there? What is the volume of this amount of apatite? What is the volume of this amount of dry collagen? What is the total volume? What is the volume percent apatite? What is the volume percent dry collagen?
Now take as a basis 100 cc of bone in vivo. What is the volume of water? What is the volume of apatite plus dry collagen? What is the volume of apatite? What is the volume of collagen? What is the volume percent apatite? What is the volume percent of collagen?
How do these answers compare with the results you obtained with your formulas?
Chet
Related to Material engineering calculation
1. What is material engineering calculation?
Material engineering calculation is the process of using mathematical and scientific principles to determine the properties and behavior of materials. This helps in designing and developing materials for various applications.
2. What are the key factors considered in material engineering calculation?
The key factors considered in material engineering calculation include material properties, such as tensile strength, elasticity, ductility, and thermal conductivity, as well as external factors like temperature, pressure, and environment.
3. How are material engineering calculations used in real-world applications?
Material engineering calculations are used in a wide range of real-world applications, such as designing and developing new materials for construction, electronics, transportation, and medical devices. They are also used in quality control and failure analysis of materials.
4. What are some common methods used in material engineering calculations?
Some common methods used in material engineering calculations include finite element analysis, stress-strain analysis, and fracture mechanics. These methods involve using mathematical equations and computer simulations to predict the behavior and performance of materials.
5. How important are material engineering calculations in the field of engineering?
Material engineering calculations are crucial in the field of engineering as they help in selecting the most suitable materials for a particular application, designing structures and components, and ensuring the safety and reliability of products. They also aid in optimizing cost and minimizing waste in the manufacturing process.
