Material Implication: True Premise, False Result
In summary, material implication is a logical operator used to represent conditional statements. It is represented by the symbols "→" or "⇒", with the premise on the left and the conclusion on the right. It can apply to any combination of truth values, but when the premise is true and the result is false, it is known as "material implication with false result". The truth table for this is true-false-true-true. Some common examples include statements such as "If it is raining, then the ground is wet" and "If you study hard, then you will get an A".
Evgeny.Makarov
MHB
2,436
I'll be linking to this post when the question arises why an implication with a false premise is true.
That was brilliant, EM! :)
FAQ: Material Implication: True Premise, False Result
What is material implication?
Material implication is a logical operator that is used to represent a conditional statement in which the truth of the premise guarantees the truth of the conclusion.
How is material implication represented?
Material implication is represented by the symbol "→" or "⇒". The premise is placed to the left of the arrow and the conclusion is placed to the right.
Does material implication only apply to true premises and false results?
No, material implication can apply to any combination of truth values for the premise and the result. However, when the premise is true and the result is false, the implication is known as "material implication with false result".
What is the truth table for material implication with false result?
The truth table for material implication with false result is as follows:
Premise Result Material Implication
true false false
false true true
true true true
false false true
What are some common examples of material implication with false result?
Some common examples of material implication with false result include: "If it is raining, then the ground is wet" (assuming that it is not currently raining), "If you study hard, then you will get an A" (assuming that you did not study hard and did not get an A), and "If you are a bird, then you can fly" (assuming that you are not a bird and cannot fly).
