Materiality of elementary particles
In summary, there is debate over whether elementary particles such as electrons and protons have material substance, as the concept of substance can be defined in different ways. However, if substance is defined as something that carries energy, momentum, and angular momentum, then these particles can be considered substance. It should be noted that protons are not elementary particles, as they are made of smaller components called quarks. Additionally, elementary particles are quantized fields and not composed of any physical matter. Despite this, they do have properties and can be thought of as the smallest units of certain elements.
David Welsh
Do elementary particles, e.g. electron, protons, etc, have material substance in the ordinary meaning of substance? If so, what is the substance?
What do you mean by "substance"? Elementary particles carry energy, momentum, and angular momentum. If you define substance as something carrying these properties, they are substance.
Protons are not elementary - they are made of quarks.
Elementary particles are really quantized fields. They are not composed of some "stuff". A field is something that has some value everywhere. Consider the gravitational and the electromagnetic fields.
I remember a physics professor calling a photon a blob of light -- that's the best macroscopic analogy that I know of.
'Material' is probably not an applicable term for sub atomic particles, unless you regard anything which has mass as material.
Before sub atomic particles were discovered it was thought that a single atom of some element was as fundamental as possible, a unit which could not be divided further.
That's still true in the sense that a single atom of (say Uranium for example) is as small an amount of Uranium as there can be.
Although we now know that atoms have component parts, a single atom is still as small as you can go and still have 'Uranium'
The component particles have no Uranium-like properties at all, (and it's the same for every other 'element' of the periodic table.
Related to Materiality of elementary particles
1. What is the materiality of elementary particles?
The materiality of elementary particles refers to their physical properties, including mass, charge, and spin. These particles are the building blocks of matter and make up everything in the universe.
2. How do we know that elementary particles have materiality?
Scientists use a variety of experimental methods, such as particle accelerators, to study and observe the behavior of elementary particles. Through these experiments, they have been able to confirm the material nature of these particles.
3. Can we see elementary particles with the naked eye?
No, elementary particles are too small to be seen with the naked eye. They are much smaller than atoms and can only be observed using specialized equipment and techniques.
4. Are there different types of materiality for elementary particles?
Yes, there are different types of elementary particles with varying material properties. For example, there are particles with positive charge, negative charge, and no charge at all. There are also particles with different masses and spins.
5. How does the materiality of elementary particles impact our understanding of the universe?
The materiality of elementary particles plays a crucial role in our understanding of the universe. By studying these particles, scientists can gain insights into the fundamental laws and forces that govern the behavior of matter and energy. It also helps us understand the origins and evolution of the universe.
  • Classical Physics
