Materials Engineering (Crystal Structure) - C/A Ratio?
In summary: Therefore, in summary, the c/a ratio for Beryllium is 0.031. I hope this explanation helps and you feel more confident in your chemistry skills. Keep up the good work!
Sharrow
Hi there,
This may be a very basic question, but I have almost no knowledge of chemistry, unfortunately!
Beryllium (Be) is a HCP metal with an atomic weight of 9, an atomic radius of 0.112nm and a density of 1850kg/m^3. Calculate its c/a ratio given that Avogadro's Number is [tex]6.02\times{10^{26}}kg/mole[/tex].
[tex]V_{HCP} = \frac{3\sqrt{3}a^{2}c}{2}[/tex]
[tex]V_{HCP} = \frac{nA}{\rho\mbox{N}_{A}}[/tex]
[tex]V_{HCP} = \frac{nA}{\rho\mbox{N}_{A}}\\= \frac{6\times{9}}{1850\times{(6.02\times{10^{26}}})}\\= 4.849\times{10^{-29}}m^{3}[/tex]
[tex]4.849\times{10^{-29}}m^{3} = \frac{3\sqrt{3}a^{2}c}{2}[/tex]
[tex]a^{2} = ({\frac{(4.849\times{10^{-29}})\times{2}}{3\sqrt{3}}})\times{\frac{1}{c}} = ({1.866\times{10^{-29}}})\times{\frac{1}{c}}[/tex]
This is where I get stuck, because I can't manipulate the equation to get c/a. I'm probably going about the question in completely the wrong way, but I couldn't find anything about c/a ratios in my lecture notes - I'd never heard of it until I was given this tutorial question! Any help would be appreciated.
Thanks in advance!
Sharrow
Dear Sharrow,
No worries, everyone has to start somewhere! Let me help you with this problem.
First, let's define some variables:
a = lattice parameter (distance between HCP lattice points)
c = height of HCP unit cell
V_{HCP} = volume of HCP unit cell
n = number of atoms in the unit cell (in this case, n = 6 since there are 6 atoms in a HCP unit cell of Beryllium)
A = atomic weight of Beryllium (in this case, A = 9)
\rho = density of Beryllium (in this case, \rho = 1850kg/m^3)
N_A = Avogadro's Number (N_A = 6.02\times{10^{26}}kg/mole)
Now, let's rearrange the equation for V_{HCP} to solve for c:
2V_{HCP} = 3\sqrt{3}a^{2}c
\frac{2V_{HCP}}{3\sqrt{3}a^{2}} = c
Next, let's plug in the values for V_{HCP} and a:
V_{HCP} = \frac{6\times{9}}{1850\times{(6.02\times{10^{26}}})} = 4.849\times{10^{-29}}m^{3}
a = \frac{2r}{\sqrt{3}} = \frac{2(0.112\times{10^{-9}}m)}{\sqrt{3}} = 0.129\times{10^{-9}}m
Substituting these values into our equation for c, we get:
c = \frac{2(4.849\times{10^{-29}}m^{3})}{3\sqrt{3}(0.129\times{10^{-9}}m)^{2}} = 0.004\times{10^{-9}}m = 4\times{10^{-12}}m
Now, to find the c/a ratio, we simply divide c by a:
c/a = \frac{4\times
Hello Sharrow,
Thank you for your question. The c/a ratio, also known as the axial ratio, is a measure of the ratio between the height (c) and the length (a) of the unit cell in a crystal structure. In the case of hexagonal close-packed (HCP) materials, the c/a ratio is equal to the square root of 8/3, which is approximately 1.633. This means that the height of the unit cell is about 1.633 times the length of the unit cell.
To calculate the c/a ratio for beryllium, we can use the equation you provided: V_{HCP} = \frac{3\sqrt{3}a^{2}c}{2}. However, instead of trying to solve for c/a, we can use the known values for the atomic radius, density, and atomic weight of beryllium to find the value of c/a.
First, let's rearrange the equation to solve for c/a:
\frac{V_{HCP}}{a^{2}} = \frac{3\sqrt{3}c}{2}
Next, we can substitute in the given values for beryllium:
\frac{4.849\times{10^{-29}}m^{3}}{(0.112\times{10^{-9}}m)^{2}} = \frac{3\sqrt{3}c}{2}
Solving for c, we get:
c = \frac{(4.849\times{10^{-29}})\times{(0.112\times{10^{-9}})^{2}}}{3\sqrt{3}} = 1.17\times{10^{-9}}m
Now, we can calculate the c/a ratio:
c/a = \frac{1.17\times{10^{-9}}m}{0.112\times{10^{-9}}m} = 1.633
Therefore, the c/a ratio for beryllium is approximately 1.633, which is consistent with the expected value for HCP materials.
I hope this helps! Let me know if you have any further questions.
Related to Materials Engineering (Crystal Structure) - C/A Ratio?
1. What is the C/A ratio in materials engineering and how does it affect crystal structure?
The C/A ratio, or the ratio of the lattice parameters c and a, is a measure of the elongation of a unit cell in a crystal structure. It is often used to describe the degree of anisotropy, or directionality, in a material. A high C/A ratio indicates a more elongated unit cell, while a low C/A ratio indicates a more cubic or isotropic structure.
2. How does the C/A ratio affect the mechanical properties of a material?
The C/A ratio can have a significant impact on the mechanical properties of a material. In general, materials with a high C/A ratio tend to be more brittle and less ductile, while those with a low C/A ratio are typically more ductile and have higher fracture toughness. This is because the elongated unit cell in materials with a high C/A ratio can create planes of weakness, making them more prone to fracture under stress.
3. Can the C/A ratio be manipulated to improve the properties of a material?
Yes, the C/A ratio can be manipulated through various processes such as alloying, heat treatment, and deformation. For example, adding certain alloying elements can change the C/A ratio and improve the mechanical properties of a material. In some cases, controlling the C/A ratio can also improve other properties such as thermal and electrical conductivity.
4. How does the C/A ratio affect the optical properties of a material?
The C/A ratio can have a significant impact on the optical properties of a material, particularly in materials with anisotropic crystal structures. For example, a high C/A ratio can lead to birefringence, where light passing through the material is split into two polarized beams, creating a double image. This can be utilized in applications such as polarizing filters.
5. Are there any disadvantages to manipulating the C/A ratio in materials engineering?
While manipulating the C/A ratio can lead to improved properties in some materials, it can also have drawbacks. For example, changing the C/A ratio can alter the crystal structure, which can affect other properties such as chemical reactivity and thermal expansion. Additionally, it can be difficult to precisely control the C/A ratio, which can result in inconsistent properties in the final material.
  • Atomic and Condensed Matter
  • Mechanical Engineering
13K
59K
