lou_skywalker
- 9
A drive shaft tube for a rear wheel drive high-performance sedan requires a lighter weight unit than one made from conventional steel. The requirements are that the applied torque be 814 N-m (600 ft-lbs) the factor of safety be 2 or more and the maximum angular displacement at full torque be no more than 3 degrees.
The shaft is 36 inches long (0.9144m) and has a fixed outer diameter of 67mm (2.637 in.).
Determine the material indices for
this application and calculate the inner diameter, weight and cost for tubes made from the candidate materials.
(tau)f/N=2M/(pi)r^3
m=L(rho)(pi)r^2
minimize (rho)/(tau)f^2/3
I can derive the term to be minimized using the above equations, just need to do it with the variables given in the problem. (especially with the inner diameter not given)
