Math Applying Einstein's Theory of General Relativity
In summary, Gravitational force follows an inverse squared distance law at small distances, but Newtonian mechanics are only an approximation for general relativity when dealing with a weak force and low speeds.
AJ Allen
Just a quick question. I've recently thought about the various equations I'm learning about calculating velocity or vertical motion and have wondered that sense these equations are using Gravity as a constant force (9.8m/s^2) Is it not true that Einsteins' theory would denounce this idea and solve these types of problems in a whole different way.
[first of all, to be precise, what you give is the acceleration and not the force]
Now, in general the constant force that you are talking about is not even true for the Newtonian mechanics. Gravitational force there follows the inverse squared distance law. At small trajectories then you can consider the force to be constant [as an approximation].
Also Newtonian mechanics are an approximation of general relativity for a weak force and low speeds...
GR then, would just add up corrections to these solutions...now whether these corrections are important or not, is a matter of the wanted accuracy/precision of your measurements. If the corrections were actually large, Newtonian mechanics wouldn't have survived for 400 years.
Newtonian theory doesn't really predict a "constant force" for gravity either, you can approximate the force of gravity on the Earth as a constant as long as your distance from the Earth's center doesn't vary much.
GR wouldn't exactly "denounce" the idea, but it would calculate things in ways that would be unfamiliar if you haven't studied GR. One way of computing the path of an object under no non-gravitational forces would be to use the geodesic equation. There are a coupe of ways of arriving at the geodesic equation which are equivalent in GR (though they are some circumstances in which these two ways are not equivalent). One computes geodesics as paths that maximize (more properly, extremize) proper time, another calculates them via techniques of parallel transport. The details are probably not going to make sense without a great deal of mathematical background, I'll refer you to Caroll's GR lecture notes http://ned.ipac.caltech.edu/level5/March01/Carroll3/Carroll3.html for more details with no guarantee that they'll be at a comprehensible level for you.
FAQ: Math Applying Einstein's Theory of General Relativity
What is Einstein's Theory of General Relativity?
Einstein's Theory of General Relativity is a mathematical theory that explains the relationship between space, time, and gravity. It proposes that gravity is not a force between masses, but rather a curvature of space and time caused by the presence of mass and energy.
How is math applied in Einstein's Theory of General Relativity?
Math is used extensively in Einstein's Theory of General Relativity to describe the curvature of space-time and how it is affected by the presence of matter and energy. The theory uses advanced mathematical concepts, such as tensor calculus, to quantitatively describe the dynamics of gravity.
What are the main equations in Einstein's Theory of General Relativity?
The main equations in Einstein's Theory of General Relativity are the Einstein field equations, which relate the curvature of space-time to the distribution of matter and energy. They are a set of 10 non-linear partial differential equations that describe the behavior of gravity.
How have Einstein's equations been tested and proven?
Einstein's equations have been tested and proven through various experiments and observations. One of the most famous examples is the observation of the bending of light by massive objects, which was predicted by Einstein's equations. Additionally, the precise predictions of the theory have been confirmed by the results of the Global Positioning System (GPS).
Can Einstein's Theory of General Relativity be applied to other areas of science?
Yes, Einstein's Theory of General Relativity has been successfully applied to various areas of science, such as cosmology and astrophysics. It has also been used to develop new technologies, such as gravitational wave detectors. Additionally, the theory has inspired new lines of research in mathematics and physics, such as string theory and loop quantum gravity.
