I Math Myth: A prime is only divisible by 1 and itself
  • I
  • Thread starter Thread starter Greg Bernhardt
    Prime
The common definition of a prime number as being only divisible by 1 and itself is misleading, as it conflates primality with irreducibility. A prime number divides a product and must also divide at least one of the factors, which is a more accurate definition. While irreducible integers are indeed prime, this relationship does not hold in all mathematical domains, such as in the ring of integers with square roots of negative numbers. An example illustrates that 6 can be factored into irreducible elements that are not prime. This nuanced understanding highlights the complexity of number theory beyond basic school definitions.
From @fresh_42's Insight
https://www.physicsforums.com/insights/10-math-things-we-all-learnt-wrong-at-school/
This is wrong. Well, yes and no. Strictly speaking, this definition describes irreducibility. And irreducibility is different from primality. A prime number is actually a number, that if it divides a product, then it has to divide one of the factors. $$7\,|\,28=2\cdot 14 \;\Longrightarrow \;7\,|\,2\text{ or }7\,|\,14$$ $$4\,|\,12=2\cdot 6\text{ but }4\,\nmid \,2 \text{ and } 4\,\nmid \,6$$ It is a bit more complicated, but it is the correct definition. However, irreducible integers are prime integers and vice versa which is why the correct definition is replaced at school by the more handy one. However, there are domains in which this is not the case. The standard example is ##\mathbb{Z}[\sqrt{-5}]## where $$6=2\cdot 3=(1+\sqrt{-5})\cdot (1-\sqrt{-5})$$ is a decomposition into irreducible factors that are not prime.
Mathematics news on Phys.org
What is going on here ?
I divided up parts of @fresh_42's latest Insight to facilitate discussion on each
That's 11 entries on the unanswered threads list !
  • Haha
Likes Greg Bernhardt
I'm glad that my teacher in grade school didn't teach these facts.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
9K
