I Math Myth: The sum of all angles in a triangle is 180°
The sum of angles in a triangle on a spherical surface exceeds 180 degrees, challenging the traditional understanding taught in schools. This phenomenon varies based on the triangle's size, making flat triangles the exception rather than the rule. The discussion highlights a common misconception about geometry in real-world applications. Participants express surprise at this revelation, indicating it was not commonly taught. Understanding this concept is crucial for grasping the complexities of geometry beyond flat surfaces.
From @fresh_42's Insight
https://www.physicsforums.com/insights/10-math-things-we-all-learnt-wrong-at-school/
Please discuss!
We all live on a globe, a giant ball. The angles of a triangle on this ball add up to a number greater than ##180°##.
And the amount by which the sum extends ##180°## isn't even constant. It depends on the size of the triangle. The flat triangle with angle-sum ##180°## is the exception, not the norm. The real world is crooked.
Mathematics news on Phys.org
This is something I never knew in school! Has anyone else heard of this before?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
9K
