Math with experimental uncertainties
In summary, we discussed the property of standard deviations of distributions when they are convoluted and how it applies to the sum of two data points with symmetrically distributed uncertainties. We also touched on the correct way to calculate the error on a function that acts on multiple uncertain data points.
Identity
152
Why is it that if you have two data points [tex]a \pm b[/tex] and [tex]c \pm d[/tex] whose uncertainties are symmetrically distributed, the sum of the points is
[tex]a+c \pm \sqrt{b^2+d^2}[/tex]
Can someone please help me with this derivation.
Also, another separate question, suppose I have many uncertain data points: [tex]x_1 \pm y_1[/tex], [tex]x_2 \pm y_2+...[/tex]. And I have a function that acts on all of them: [tex]f(x_1 \pm y_1, x_2 \pm y_2,...,x_n \pm y_n)[/tex]
Is the following reasoning valid:
Choose [tex]x_i \pm y_i[/tex] in order to maximize f.
(For instance, if I had f(\frac{1}{x \pm y}) you would choose [tex]x -y[/tex] to maximize f.)
Next, you choose [tex]x_i \pm y_i[/tex] in order to minimize f.
Once you have f_{max} and f_{min}, you find the average of the two, so you have:
f(x_1 \pm y_1, x_2 \pm y_2,..., x_n \pm y_n) = \frac{f_{max}+f_{min}}{2} \pm \frac{f_{max}-f_{min}}{2}
(SORRY FOR NO LATEX, THE LATEX CODE IS GIVING A COMPLETELY DIFFERENT EQUATION!)
Thanks!
Mathematics news on Phys.org
It is a property of standard deviations of distributions that when they are convoluted, the standard deviation of the result is the square root of the sum of the squares of the standard deviations.
In other words: consider a random variable B giving your first error (with standard deviation b), and consider another random variable D giving your second error (with standard deviation d).
If we assume that B and D are statistically independent, we can consider the distribution of the random variable F = B + D, and we know then that the probability distribution of F will be the convolution of the one of B and the one of D (if they ARE statistically dependent, this is not true anymore).
F is the error on the sum of course. So the probability distribution of the error of the sum (namely of F) is the convolution of the distributions of B and of D. It is a property of the convolution that the standard deviation of the distribution of F, say, f, is given by sqrt(b^2 + d^2).
Hence, f = sqrt(b^2 + d^2).
As to your second question, what you do is a kind of heuristic guessing, which might give an answer that is not too far from the right answer, but it is not a correct technique (although, as I said, heuristically maybe useful, say in a computer program that has to give you some rough estimate of the error).
The correct way to to, at least if the errors are small so that the function f can be linearized over the range of the errors, is to calculate sqrt( (df/dx1 * y1)^2 + (df/dx2 * y2)^2 +... (df/dxn * yn)^2 )
The explanation is close to that of the first question: you construct a new random variable (the error on the outcome), which will in this case be a weighted sum of the random variables representing the errors y1, y2, ...yn.
This is obtained by linearizing f around f(x1,x2,...xn).
Thanks vanesch :)
FAQ: Math with experimental uncertainties
1. What is experimental uncertainty in math?
Experimental uncertainty in math refers to the degree of error or imprecision in measuring a quantity or calculating a value. It is a measure of the confidence or reliability of a result.
2. How is experimental uncertainty calculated?
Experimental uncertainty is calculated by taking the average of a set of measurements and determining the range of values that fall within a certain level of confidence, typically 95%. This range is then used to determine the uncertainty associated with the measurement.
3. What are some common sources of experimental uncertainty in math?
Some common sources of experimental uncertainty in math include measurement errors, rounding errors, limitations of measuring tools, and human error in recording or analyzing data.
4. How does experimental uncertainty impact the validity of mathematical results?
Experimental uncertainty can impact the validity of mathematical results by introducing a level of doubt or imprecision. If the uncertainty is too high, it may be difficult to draw accurate conclusions or make precise predictions based on the data.
5. What are some ways to reduce experimental uncertainty in math?
Some ways to reduce experimental uncertainty in math include using more precise measuring tools, increasing the number of measurements taken, and using statistical analysis techniques to determine the level of uncertainty. Proper training and careful attention to detail can also help reduce human error.
11K
