Math wrong with physics springs problem
In summary, the two springs in parallel will be compressed by a force of 5kg and will end up being 2.5 cm apart.
math111
43
Problem:A force of 5kg compresses the spring in series 10cm. What will be the total distance that the springs in parallel are compressed.
Givens: S1,S2,S3,S4 are in parallel being forced by a 5kg weight.
F=-kx but k is not given so it is assumed to be 1
(1) S1 and S2 in series with 5 Kg load: S1 gets the 5Kg load and S2 gets the 5 Kg Load so S1+S2 = 10Kg total load. F=kX-->10Kg=(1)(X)--> X=10cm
Example given with solution
(2)S1 and S2 in parallel with 5 Kg load:S1 and S2 get the 5Kg Load so there is a split among them. S1+S2 = 5kg-->5Kg=(1)(X)-->X=5cm
This is where my issue is
(3)S1,S2,S3,S4 are in parallel with a 5Kg load: S1 and S2 and S3 and S4 get the 5Kg load so there is a split among them. S1+S2+S3+S4=5Kg-->5Kg=(1)(X) = 5cm.
How can having two springs in parallel(2) and four spring in parallel(3) be the same?
I have a feeling my math in wrong so please help me if posible.
Why did you assume that k = 1? Why not calculate it?
Do you know the equations for calculating k equivalent for both parallel and series springs?
Be sure to include units when calculating spring constants.
If K is not given then your saying K is relevant then ok...
Spring in Series: Keq=1/Keq=1/K1+1/K2
Spring in Parallel: Keq=K1+K2
Equivalent Spring Constant (Parallel)[in my problem]
F=F1+F2+F3+F4
F=-k1X-k2X-K3X-k4X
F=-(k1+k2+k3+k4)X
5=-(4)X
X=1.25cm for 4 springs in parallel now ?
For series initial problem:
F=-(k1k2/(k1+k2))X
5=-(1/2)X
X=10 which matches the given answer
I am assuming K=1 still because it is not given.
Yes, 1.25 cm is correct for the 4 springs compressed in parallel.
Basically, you have checked, and confirmed that if k = 1 kg/cm the series deflection matches that in the question. Luckily, your assumption was correct.
A better way of approaching the problem would be to calculate the k value of the spring based on the series deflection, and then calculate the parallel deflection.
This is where this is all stem from...
http://www.psychometric-success.com/aptitude-tests/mechanical-reasoning-tests-springs.htm
1. A force of 5 Kg compresses the springs in series 10cm.What will be the total distance that the springs in parallel are compressed? 2 springs
A) 10cms
B) 2.5cms
C) 5cms
D)7.5 cms
Answer to Question
1. C – The total force will be divided equally between the 2 springs in parallel. Since the force is divided in half, the distance moved will also be halved. The springs in series were compressed 10 cms, so the springs in parallel will be compressed 5 cms.
It should be 'B' right!
F=F1+F2
F=-k1X-k2X
F=-(k1+k2)X
5=-(2)X
X=2.5cm for 2 springs!
:bugeye:
Related to Math wrong with physics springs problem
1. What is the "Math wrong with physics springs problem"?
The "Math wrong with physics springs problem" refers to a common issue in physics involving the use of mathematical equations to solve problems related to springs. It is a mathematical error that can lead to incorrect results and affect the accuracy of scientific experiments.
2. What causes the "Math wrong with physics springs problem"?
The "Math wrong with physics springs problem" can be caused by various factors, such as incorrect application of equations, miscalculations, and assumptions that do not accurately represent the physical system being studied. It can also result from using simplified or idealized models that do not account for real-world complexities.
3. How can the "Math wrong with physics springs problem" be avoided?
To avoid the "Math wrong with physics springs problem," scientists and researchers must carefully check their calculations and assumptions, use accurate and appropriate equations, and consider the limitations of their models. It is also important to validate results with experimental data and seek peer review to identify any potential errors.
4. What are the consequences of the "Math wrong with physics springs problem"?
The consequences of the "Math wrong with physics springs problem" can vary depending on the severity of the error and the context of the research. In some cases, it may lead to incorrect conclusions and a waste of time and resources. In more critical situations, it can have serious implications for the accuracy and validity of scientific findings.
5. Can the "Math wrong with physics springs problem" be fixed?
Yes, the "Math wrong with physics springs problem" can be fixed by identifying the source of the error and correcting it. This may involve reworking calculations, adjusting assumptions, or using different models or equations. It is essential to address the problem promptly to ensure accurate and reliable results.
