[Mathematica] : Method to import C-Code to Expressions
In summary, the individual is looking for a way to import an old, complex C code generated from Mathematica back into Mathematica automatically. They have attempted to do so manually with the StringReplace function but have encountered issues. They are wondering if there is a package or method that can help with this task and if Mathematica is able to import or convert C code. They have also shared a potential solution using the ToExpression function and replacing "pow" with "Power."
Hepth
40
I have some ugly c-code that was generated from Mathematica in years past with CForm, and looks like :
Code:
(PolyLog (2,(-1 + t)*pow (-1 + q2h,-1))*pow (q2h - t,-1)*pow (-1 + \
t,-1)*
     (-8*pow (q2h,3)*pow (t,2) + pow (q2h,4)*(1 + pow (t,2)) -
       8*q2h*pow (t,3)*(-3 + 8*t - 5*pow (t,2) + pow (t,3)) +
       pow (q2h,2)*pow (t,2)*(-13 + 40*t - 16*pow (t,2) + pow (t,4)) +
       pow (t,4)*(-10 + 24*t - 13*pow (t,2) + pow (t,4)))*
     pow (q2h - pow (t,2),-3))/8. -
  (PolyLog (2,-((q2h - t)*(q2h + (-1 + 2*ctf)*t)*pow (ctf,-1)*pow \
(t,-2))/2.)*
     pow (q2h - t,-1)*pow (-1 + t,-1)*
I would like to import this back into Mathematica in an automatic way, as the true expressions are many pages long.
I tried by hand with things like : StringReplace[%, {"pow(t," ~~ Shortest[b__] ~~ ")" :> "Power[t," ~~ b ~~ "]"}];
but it gets ugly, and sometimes makes mistakes.
Is there a package or method that exists that would let me do this? Can Mathematica import C code at all, or convert it if its simple (like this)?
Thanks!
-Hepth
Your string has issues; check out for backslashes (and maybe dots, if you don't want inexact numerics), for example
Once done, try this:
ToExpression[string, TraditionalForm, HoldComplete] /. pow -> Power
Worked OK for me.
Related to [Mathematica] : Method to import C-Code to Expressions
1. How can I import C-Code into Mathematica?
To import C-Code into Mathematica, you can use the Import function and specify the file path to the C-Code file. You can also use ImportString to directly paste the C-Code into Mathematica.
2. Can I convert C-Code into Mathematica expressions?
Yes, you can convert C-Code into Mathematica expressions using the ToExpression function. However, note that this method may not work for all C-Code and may require some manual modifications.
3. Is there a specific format for the C-Code that can be imported into Mathematica?
Yes, the C-Code must be in a valid Mathematica syntax format for it to be successfully imported. This means that it must be written using Mathematica functions and operators, rather than C syntax.
4. Can I use C-Code imported into Mathematica for calculations?
Yes, you can use C-Code imported into Mathematica for calculations by converting it into Mathematica expressions. However, note that the performance may not be as efficient as using built-in Mathematica functions.
5. Are there any limitations in importing C-Code into Mathematica?
Yes, there are some limitations when importing C-Code into Mathematica. For example, certain C-Code features or functions may not be supported by Mathematica, or the import may not be successful if the C-Code is too complex or not in a valid Mathematica syntax format.
