Mathematica NDSolve Running Infinitely
In summary, Mathematica never reaches an answer nor does it give an error, it simply runs infinitely. This is for a class final project that's worth a large portion of my grade.
AtLastForgot
I'm trying to use Mathematica to solve a system of equations based on coordinate transformations and Lagrangian mechanics. The code follows here. However, when the system of equations is run, Mathematica never reaches an answer nor does it give an error, it simply runs infinitely. This is for a class final project that's worth a large portion of my grade.
(*Definition of various functions which will help us simplify our \
code later. None of this is physically relevant; it is simply a \
convenience.*)
g[x_, y_, \[Theta]_] := {{Cos[\[Theta]], -Sin[\[Theta]],
x}, {Sin[\[Theta]], Cos[\[Theta]], y}, {0, 0, 1}}
unhat[a_] := {a[[1, 3]], a[[2, 3]], a[[2, 1]]}
hat[a_] := {{0, -a[[3]], a[[1]]}, {a[[3]], 0, a[[2]]}, {0, 0, 0}}
Hom[point_] := Flatten[{point, 1}]
Unhom[point_] := {point[[1]], point[[2]]}
Clear[m1, m2, m3, J1, J2, J3, L1, L2, L3, grav]
(*The first transformation from an origin of 0,0 to the primary axes \
of the first bar.*)
gUpperArm[x_, y_, \[Theta]1_] := g[x, y, 0].g[0, 0, \[Theta]1];
(*Velocity of this point is determined both in terms of translational \
velocities as well as rotational. Unhat allows us to calculate this \
quantity, normally [g^-1][g'], via simple notation.*)
VUpperArm =
unhat[Inverse[gUpperArm[x[t], y[t], \[Theta]1[t]]].D[
gUpperArm[x[t], y[t], \[Theta]1[t]], t]];
(*Transformation from origin to the primary axes of the second bar \
using intermediate steps of the first transformation. This links \
their two motions and allows us to calculate VForearm, a quantity \
which would otherwise be extremely difficult to describe.*)
gForearm[x_, y_, \[Theta]1_, \[Theta]2_] :=
gUpperArm[x, y, \[Theta]1].g[L1/2, 0, 0].g[0, 0, \[Theta]2].g[L2/2,
0, 0];
VForearm =
unhat[Inverse[gForearm[x[t], y[t], \[Theta]1[t], \[Theta]2[t]]] .
D[gForearm[x[t], y[t], \[Theta]1[t], \[Theta]2[t]], t]];
gWeapon[x_, y_, \[Theta]1_, \[Theta]2_, \[Theta]3_] :=
gForearm[x, y, \[Theta]1, \[Theta]2].g[L2/2, 0, 0].g[0,
0, \[Theta]3].g[L3/4, 0, 0];
VWeapon =
unhat[Inverse[
gWeapon[x[t], y[t], \[Theta]1[t], \[Theta]2[t], \[Theta]3[t]]] .
D[gWeapon[x[t], y[t], \[Theta]1[t], \[Theta]2[t], \[Theta]3[t]],
t]];
(*Definitions of inertia for the various components of the system. \
Notice that the form is x,y,\[Theta].*)
IUpperArm = DiagonalMatrix[{m1, m1, J1}];
IForearm = DiagonalMatrix[{m2, m2, J2}];
IWeapon = DiagonalMatrix[{m3, m3, J3}];
(*Calculations of Kinetic Energy using previously defined \
transformations to make this otherwise nearly impossible task much \
simpler.*)
KE = ((1/2)*VUpperArm.IUpperArm.VUpperArm) + ((1/2)*
VForearm.IForearm.VForearm) + ((1/2)*VWeapon.IWeapon.VWeapon);
V = m1*grav*(gUpperArm[x[t], y[t], \[Theta]1[t]].{0, 0, 1})[[2]] +
m2*grav*(gForearm[x[t], y[t], \[Theta]1[t], \[Theta]2[t]].{0, 0,
1})[[2]] +
m3*grav*(gWeapon[x[t],
y[t], \[Theta]1[t], \[Theta]2[t], \[Theta]3[t]].{0, 0, 1})[[
2]];
Lag = KE - V;
EQ1 = D[D[Lag, x'[t]], t] - D[Lag, x[t]];
EQ2 = D[D[Lag, y'[t]], t] - D[Lag, x[t]];
EQ3 = D[D[Lag, \[Theta]1'[t]], t] - D[Lag, \[Theta]1[t]];
EQ4 = D[D[Lag, \[Theta]2'[t]], t] - D[Lag, \[Theta]2[t]];
EQ5 = D[D[Lag, \[Theta]3'[t]], t] - D[Lag, \[Theta]3[t]];
EQ = Solve[{EQ1 == 0, EQ2 == 0, EQ2 == 0, EQ4 == 0, EQ5 == 0}, {x[t],
y[t], \[Theta]1[t], \[Theta]2[t], \[Theta]3[t]}];
I can give you a general guideline which I think works well: keep stripping down your code until it works, run a simpler version of your code, use explicit values of constants rather than assigned values, cut down the actual differential equations, drop some of the terms, make the terms simpler. Then once you get it working with just a bare-bones version even if it's significantly different than what you want, start building it back up piece by piece and in that way, a small piece by piece, you'll have a better handle on a problem when it occurs because you'll know specifically what you added last that caused the problem and can then focus on that addition and hopefully resolve it.
Thanks. I think I managed to get a working version going, but now I'm getting different errors. Hurray for computer programming!
Related to Mathematica NDSolve Running Infinitely
1. Why does my Mathematica NDSolve code seem to never finish running?
There are a few possible reasons for this. One common issue is that the system of differential equations being solved may be very complex or have a large number of solutions, causing the calculation to take a long time. Another possibility is that the code may have a mistake or error, causing it to get stuck in an infinite loop. It is also possible that the code is running correctly, but the solution to the differential equations is taking a long time to converge.
2. How can I speed up Mathematica NDSolve when solving complex differential equations?
There are a few strategies you can try to speed up the calculation. One approach is to simplify the equations as much as possible before running them through NDSolve. You can also try specifying specific methods and options for NDSolve that may be more efficient for your particular problem. Additionally, using parallel computing or distributing the calculation across multiple processors can also help speed up the process.
3. I keep getting an error message when using NDSolve. What should I do?
First, make sure to carefully read and understand the error message. It may provide important clues as to what is causing the issue. If you are still unsure, try searching online for the error message or consulting the Mathematica documentation for NDSolve. You can also try simplifying your code or using different options or methods to see if that resolves the issue.
4. Can Mathematica NDSolve handle systems of partial differential equations?
Yes, NDSolve can solve systems of both ordinary and partial differential equations. However, it is important to carefully specify the boundary and initial conditions for the partial differential equations in order to get an accurate solution. Additionally, some partial differential equations may require special methods or options to solve correctly.
5. Can I use NDSolve to solve equations with discontinuous or non-smooth solutions?
Yes, NDSolve can handle equations with discontinuous or non-smooth solutions, but it may require specifying special options or methods. For example, the option "DiscontinuityProcessing" can be used to handle equations with discontinuous solutions. It is also important to carefully specify the initial conditions and boundaries for these types of equations to get an accurate solution.
