McLaren Rulez
- 292
- 3
Hi,
So here's my latest problem as I get to grips with Mathematica. I will give a simpler version of the one I am actually doing.
I started with a closed set of differential equations. Consider the following equations
[tex]a'(t)=P*b(t)[/tex]
[tex]b'(t)=P^{2}*a(t)[/tex]
with known initial conditions and P is a constant. I solved it for a specific value of P using s=NDSolve[...] with the equations and initial conditions inside the NDSolve argument. I can get a plot of a(t) against t using Plot[Evaluate[a(t)/.s], {t, 0, Infinity}]. So far, so good. Now, I want to get a feel for how the system behaves for an arbitrary P. I tried to upgrade s to a function that takes in argument p. That is, s[P_]=NDSolve[...] and this works as well. So now, I can input s[5] and get the solution of my DEs for P=5, say. Note that now, I have to use Plot[Evaluate[a(t)/.s[5], {t, 0, Infinity}] to get my plot of a(t) against t.
Similarly, I can get a plot of a[t] against P for a given t. That is, Plot[Evaluate[a(1)/.s[P], {P, 0, Infinity}] works too. But for some reason, this takes a very long time. It takes a good two or three minutes for each value of t. Why is it so slow?
I eventually want to get a 3D plot of a(t) against t and P. I'm not sure how to go about it and even if I did, if it takes two or three minutes for one value of t, it will never be able to do a 3D plot of all t and all P, will it?
Thank you for your help.
