(Mathematica) Poincarè map of restricted three body problem
In summary: Point@ {First[Evaluate[x[#] /. mysol]], First[Evaluate[y[#] /. mysol]], First[Evaluate[z[#] /. mysol]]} & /@ mypoints;sg1 = Show[Graphics3D[{Red, PointSize[0.008], myplots}]];(* show everything *)Show[{pp
federes
Hi everybody,
sorry for the inconvenience.
I try to plot the poincarè map of the restricted three body problem. I find in this forum the follow script that do this for the Lorenz system:
mysol = NDSolve[{x'[t] == -3 (x[t] - y[t]),
y'[t] == -x[t] z[t] + 26.5 x[t] - y[t], z'[t] == x[t] y[t] - z[t],
x[0] == z[0] == 0, y[0] == 1}, {x, y, z}, {t, 0, 200},
MaxSteps -> 100000]
myx[t_] := Evaluate[x[t] /. mysol];
myplot = Plot[myx[t], {t, 0, 200}]
pp1 = ParametricPlot3D[
Evaluate[{x[t], y[t], z[t]} /. mysol], {t, 0, 200},
AxesLabel -> {"x", "y", "z"}, PlotPoints -> 150]
cp1 = ContourPlot3D[x == 0, {x, -20, 20}, {y, -20, 20}, {z, 0, 50},
Mesh -> None, ContourStyle -> {LightPurple, Opacity[0.4]}]
(* get line segments from plot *)
pts = Cases[myplot, Line[{t__}] -> t, \[Infinity]];
(* from set above, select all pairs which exhibit a sign change to \
identify a root *)
myselection =
Select[Split[pts, Sign[Last[#2]] == -Sign[Last[#1]] &],
Length[#1] == 2 &];
(* get first element of the array *)
mymap = Map[First, myselection, {2}];
(* find in line segments where each changes sign *)
mymap2 = Map[FindRoot[myx[t] == 0, {t, #[[1]], #[[2]]}] &, mymap];
mypoints = t /. mymap2;
(* plot Poincare map where x[t]=0 *)
myplots =
Show[{pp1, cp1, sg1}]
And this for the Hénon-Heiles (from mathematica " tutorial/NDSolveEventLocator " ):
Needs["DifferentialEquations`NDSolveProblems`"];
system = GetNDSolveProblem["HenonHeiles"];
vars = system["DependentVariables"]; eqns = {system["System"],
system["InitialConditions"]}
Off[NDSolve::noout];
sdata =
Reap[
NDSolve[eqns, {}, {T, 3000},
Method -> {"EventLocator", "Event" -> Subscript[Y, 1][T],
"EventAction" :> Sow[{Subscript[Y, 2][T], Subscript[Y, 4][T]}],
"EventLocationMethod" -> "LinearInterpolation",
"Method" -> {"SymplecticPartitionedRungeKutta",
"DifferenceOrder" -> 4,
"PositionVariables" -> {Subscript[Y, 1][T],
Subscript[Y, 2][T]}}},
StartingStepSize -> 0.25, MaxSteps -> \[Infinity]];
psdata = sdata[[-1, 1]];
ListPlot[psdata, Axes -> False, Frame -> True, AspectRatio -> 1]
Now the question is:
Could everyone help me to find a method to show the Poincarè surface for the restricted three body problem?
Thanks a lot to everybody !
</code>I am sorry for the inconvenience. I would like to plot the poincaré map of the restricted three body problem. I found in this forum the following script that does this for the Lorenz system:<code>mysol = NDSolve[{x'[t] == -3 (x[t] - y[t]), y'[t] == -x[t] z[t] + 26.5 x[t] - y[t], z'[t] == x[t] y[t] - z[t], x[0] == z[0] == 0, y[0] == 1}, {x, y, z}, {t, 0, 200}, MaxSteps -> 100000]myx[t_] := Evaluate[x[t] /. mysol];myplot = Plot[myx[t], {t, 0, 200}]pp1 = ParametricPlot3D[ Evaluate[{x[t], y[t], z[t]} /. mysol], {t, 0, 200}, AxesLabel -> {"x", "y", "z"}, PlotPoints -> 150]cp1 = ContourPlot3D[x == 0, {x, -20, 20}, {y, -20, 20}, {z, 0, 50}, Mesh -&gt; None, ContourStyle -&gt; {LightPurple, Opacity[0.4]}](* get line segments from plot *)pts = Cases[myplot, Line[{t__}] -&gt; t, \[Infinity]];(* from set above, select all pairs which exhibit a sign change to \identify a root *)myselection = Select[Split[pts, Sign[Last[#2]] == -Sign[Last[#1]] &amp;], Length[#1] == 2 &amp;];(* get first element of the array *)mymap = Map[First, myselection, {2}];(* find in line segments where each changes sign *)mymap2 = Map[FindRoot[my
Related to (Mathematica) Poincarè map of restricted three body problem
1. What is the Poincarè map of the restricted three body problem?
The Poincarè map of the restricted three body problem is a tool used in celestial mechanics to study the motion of a small mass orbiting around two larger masses, such as a planet and its moon. It is named after the French mathematician Henri Poincarè who first developed the concept in the late 19th century.
2. How is the Poincarè map constructed?
The Poincarè map is constructed by plotting the positions and velocities of the small mass at regular intervals of time, known as Poincarè sections. These sections are typically chosen at specific points in the orbit, such as when the small mass is at its closest approach to one of the larger masses.
3. What information can be obtained from the Poincarè map?
The Poincarè map provides a visual representation of the dynamics of the three body system. It can reveal important information such as stable and unstable regions of the orbit, as well as the effects of gravitational perturbations from the two larger masses on the small mass.
4. How is the Poincarè map used in research?
The Poincarè map is a valuable tool for studying the long-term behavior of celestial bodies in three body systems. It is used in research to analyze the stability and predictability of orbits, as well as to investigate the effects of external perturbations on the dynamics of the system.
5. Are there any limitations to the Poincarè map?
While the Poincarè map is a useful tool for analyzing the restricted three body problem, it does have some limitations. It assumes that the masses of the two larger bodies are much larger than the small mass, and that their orbit is circular. It also does not take into account other factors such as atmospheric drag or gravitational interactions with other nearby bodies.
