Mathematical Biology (non-dimensionalise)
In summary: NP - \frac{d}{cN_0}P = \alpha uv - \beta u\end{equation}4. Non-dimensionalize the time: Finally, we non-dimensionalize the time variable by defining a new time scale $\tau = \frac{t}{a}$. Substituting this in the above equations and simplifying, we get the desired non-dimensionalized equations:\begin{equation}\frac{du}{d\tau} = u(1-u-v)\end{equation}\begin{equation}\frac{dv}{d\tau} = \alpha v(u-\beta)\end{equation}These equations are equivalent to the original ones
ra_forever8
129
Consider the predator-prey system defined by
\begin{equation} \frac{dP}{dt}= aP(1-\frac{N}{K})-bPN= f(N,P)----------(1)
\end{equation}
\begin{equation} \frac{dN}{dt}=cNP-dP= g(N,P)--------------(2)
\end{equation}
with initial conditions $P=P_{0}$ and $N=N_{0}$,
Where $N=N(t)$ is the prey density and $P=P(t)$ is the predator density. Here $a,b,c,d$ and $K$ are all positive constants.
Non-dimensionalise equations (1) and (2) to obtain
\begin{equation} \frac{du}{d\tau}=u(1-u-v)= f(u,v)
\end{equation}
\begin{equation} \frac{dv}{d\tau}=\alpha v(u-\beta)= g(u,v)
\end{equation}
with $u=u_{0}$ and $v=v_{0}$,
where $\alpha = \frac{cK}{a}$ and $\beta= \frac{d}{cK}$=> I try to do by saying Non-dimensionalise parameter to be
$P= au$, $N=Xv$ and $t=\frac{\tau}{a}$, where I can choose $X= \frac{K}{b}$, but it did not works. can anyone please help to get Non-dimensionalise equations.
Mathematics news on Phys.org
Thank you for your question. Non-dimensionalization is a common technique used in mathematical modeling to simplify and analyze complex systems, and it can be very useful in studying predator-prey systems.
To non-dimensionalize the given system, we can follow a few steps:
1. Define new variables: Let us define new variables $u=\frac{P}{P_0}$ and $v=\frac{N}{N_0}$. These variables represent the relative densities of predators and prey, respectively, compared to their initial values $P_0$ and $N_0$.
2. Rewrite the equations: Using the new variables, the original equations (1) and (2) can be rewritten as:
\begin{equation}
\frac{dP}{dt} = aP_0(1-\frac{N_0}{K}v)-bP_0PN = aP_0(1-v)-bP_0Pv = aP_0(1-u-v)
\end{equation}
\begin{equation}
\frac{dN}{dt} = cN_0P-dP = cN_0P_0uv-dP_0u = cN_0P_0(uv-\frac{d}{c}u)
\end{equation}
3. Non-dimensionalize the parameters: To non-dimensionalize the parameters, we can use the following relations:
\begin{equation}
u = \frac{P}{P_0} = \frac{aP}{aP_0} = \frac{a}{aP_0}P
\end{equation}
\begin{equation}
v = \frac{N}{N_0} = \frac{cN}{cN_0} = \frac{c}{cN_0}N
\end{equation}
Substituting these relations in the original equations, we get:
\begin{equation}
\frac{du}{dt} = \frac{a}{aP_0}P(1-\frac{c}{cN_0}N) - \frac{b}{aP_0}PN = u(1-\alpha v) - \beta uv
\end{equation}
\begin{equation}
\frac{dv}{dt} = \frac{c}{cN_
FAQ: Mathematical Biology (non-dimensionalise)
What is mathematical biology and how is it related to non-dimensionalisation?
Mathematical biology is a field that uses mathematical tools and models to study biological systems and phenomena. Non-dimensionalisation is a technique used in mathematical biology to simplify and analyse these models by removing units and scaling variables to a common dimensionless form. This allows for easier interpretation and comparison of results.
Why is non-dimensionalisation important in mathematical biology?
Non-dimensionalisation is important in mathematical biology as it can reveal underlying patterns and relationships in complex systems, making them more understandable and easier to study. It also allows for the comparison of different systems and models, and can help identify key parameters that affect the behavior of the system.
How is non-dimensionalisation performed in mathematical biology?
Non-dimensionalisation is typically performed by selecting appropriate reference variables for the system and expressing all other variables in terms of these references. This results in a set of dimensionless parameters that can be used to simplify and analyse the model. Different methods of non-dimensionalisation can be used depending on the specific system being studied.
What are some applications of non-dimensionalisation in mathematical biology?
Non-dimensionalisation has a wide range of applications in mathematical biology. It can be used to study biological processes such as population growth, disease spread, and enzyme kinetics. It is also commonly used in biomechanics to model movement and forces in biological systems. Additionally, non-dimensionalisation plays a crucial role in developing and testing hypotheses in evolutionary biology.
What are the advantages of using non-dimensionalisation in mathematical biology?
Non-dimensionalisation offers several advantages in mathematical biology. It simplifies complex models, making them easier to analyze and interpret. It also allows for the comparison and generalization of different systems, leading to a deeper understanding of biological phenomena. Non-dimensionalisation also helps identify key parameters that influence the behavior of the system, allowing for more targeted and efficient research.
