Mathematical induction/factoring
  • Mathematica
  • Thread starter L²Cc
  • Tags
    Mathematical
In summary, the given expression can be factored as (k+1)(k+2)(k+3) * [k+4]. The common factor is (k+1)(k+2)(k+3) and this was found by noticing that both terms have (k+1)(k+2)(k+3) in common. It is not necessary to expand the polynomials to find the common factor. Substituting (k+x) by different variables (such as A, B, etc.) may make it easier to spot the common factor. An example was provided to illustrate this concept.
L²Cc
149
[k(k+1)(k+2)(k+3) + 4(k+1)(k+2)(k+3)]/4
Please, factor this out...
What's the common factor? How did you get there? (ok i hope it doesn't require expanding the polynomials :p)
would it be easier if i substituted every (k+x) by a different variable, where (k+1) would equal to variable 'A', (k+2) = B, and so forth?
Here's an example that may help:
(x+7)(x+8)(x+9) + (x+7)(x+11)(x+13)
Notice that both terms have (x+7) in common; so it's a common factor.
You can factor this as (x+7) * [(x+8)(x+9) + (x+11)(x+13)]
oh all right i see,
thanks a lot, take care!
Related to Mathematical induction/factoring
1. What is mathematical induction?
Mathematical induction is a method of proving a mathematical statement or formula by proving it is true for an initial value, and then showing that if it is true for any value, it is also true for the next value. This process is repeated until the statement is proven to be true for all values.
2. How is mathematical induction used in proofs?
Mathematical induction is used in proofs to show that a statement is true for all values in a given set. It allows for the proof to be broken down into smaller, more manageable steps, making it easier to prove the statement for all values.
3. What is the difference between strong and weak induction?
Strong induction is a variation of mathematical induction where instead of proving the statement for the next value, it is proven for all values up to and including the next value. Weak induction only requires the statement to be proven for the next value.
4. What is factoring in mathematics?
Factoring is the process of breaking down a mathematical expression into smaller, simpler parts. It is commonly used in algebra to solve equations and simplify expressions.
5. How is factoring used in real-world applications?
Factoring is used in many real-world applications, such as in finance to calculate interest rates and in physics to solve equations for motion and forces. It is also used in engineering, computer science, and other fields to solve complex problems and equations.
