Mathematical model of Newton's first law
In summary: The equation F=ma is a mathematical model for the force between two masses. It is not a model for the change in motion.The equation F=ma is a mathematical model for the force between two masses. It is not a model for the change in motion.
fedecolo
61
Is there a mathematic model for the first law of dynamics? If no, do you think that this law can be modellized with maths?
Science news on Phys.org
F=ma
Likes benorin and ISamson
russ_watters said:
F=ma
The first law is the principle of inertia :|
Yes...
Can you give its formulation? Then we can look for a mathematical statement.
No, the first law is the qualitative part of the definition of force (force is the only cause for changes in motion). Therefore there is no corresponding mathematical model. But it should be possible to find a logical expression. The quantitative part of the definition is given in the second law (##F = \dot p##) and the third law(##F_1 = - F_2##).
Likes Delta2
The 1st and 2nd law are summarized by the statetment that there exists an inertial reference frame such that
$$\mathrm{d \vec{p}}{\mathrm{d} t}=\vec{F}.$$
If there's no force you have
$$\vec{p}=\text{const}.$$
This is the 1st Law: For a point-particle like body with constant mass you have ##\vec{p}=m \vec{v}## and thus ##\vec{v}=\text{const}##, i.e., a point particle moves with constant velocity against an inertial reference frame, if no force is acting on the body.
Likes Dr.D and S.G. Janssens
No, it just means that a body with constant mass moves with constant velocity if no force is acting on it. Without the third law this is not limited to inertial frames.
I don't understand this. Are you saying that the first law by itself holds in non-inertial frames as well? Do you have fictitious forces in mind?
In, e.g., a reference frame ##(t,\vec{x}')## which is accelerated with uniform acceleration against an inertial frame ##(t,\vec{x})##, you have
$$\vec{x}=\vec{x}'-\frac{\vec{a}}{2} t^2.$$
If no force is acting, you have
$$\ddot{\vec{x}}=\ddot{\vec{x}}'-\vec{a}=0,$$
from which
$$\vec{x}'=\frac{\vec{a}}{2} t^2 + \vec{v}_0' t + \vec{x}_0', \quad \vec{v}'=\vec{a} t+\vec{v}_0' \neq \text{const}.$$
I think this utmost simple example is understandable even without this calculation!
Yes, sure.
That is why I found post #8 confusing, which led to my remark in #9.
Yes, without the third law there is no difference between interactive forces and fictitious forces. In order to make all three laws valid in non-inertial frames you just need to remove the first sentence of the third law. Newton did that in his personal copy of the Principia [http://cudl.lib.cam.ac.uk/view/PR-ADV-B-00039-00001/49].
Likes S.G. Janssens
The 3rd law is more about homogeneity of space, i.e., momentum conservation rather than inertial frames. I'm still puzzled about your statement that Newton's laws read all the same in non-inertial frames. The very basis of Newtonian mechanics from a modern point of view is Galilei invariance, which leads to the inertial frames as a kind of preferred frames.
vanhees71 said:
from which
Without the third law this just means that there is a force acting in the accelerated frame.
Well, my question come from a ordinary life problem. When I am on the train, and it starts going foward, I feel pushed backward because I tend to maintain my state of quiet (let's call state ##A##). But after some while I don't feel a force pushing me because I am now in a state of steady speed (state ##B##). So my inertia switched from quiet to steady speed. And my question is: is there a mathematic model that correlates all the variables (time, my mass, the acceleration of the train, etc...)? Because if I say the simple equation F=ma or v =at, I know my speed at any time, but I don't know if I feel a force pushing me backwards!
You feel the force pushing you forward! It's most simply understood if you look at your acceleration inside the train from an inertial frame (e.g., (to a good approximation) the frame of an observer at rest on the platform): Then you see that there must be a force acting on you (or your center of mass) such that you get accelerated, and Newton's 2nd Law tells you the this force is given by ##\vec{F}=m \vec{a}##.
Likes russ_watters
If you know your mass and speed at any time you would also know the force acting on you if there would be no third law. It becomes tricky when you distinguish between interactive forces and fictious forces. Then you need to find a frame of references where total momentum is conserved. That can be the rest frame of the platform as vanhees71 already suggested.
That depends on the frame of reference your brain is currently using for the processing of the cognitive input. Inside a train this may be the rest frame of the train (depending on where you are looking at) and then you feel a force pushing you backwards.
Likes fedecolo
Only if you are not a physicist knowing that these are inertial forces (sometimes called fictitious forces, but that's a misnomer in my opinion, because as you rightfully say you "feel" them and they have of course an impact on the motion of matter, e.g., the Coriolis force on Earth for the motion of the air).
Beeing a physicist is neither required nor sufficient to know that these are inertial forces. It can be very hard or even impossible to distinguish inertial frames of reference from non-inertial frames.
There is no mathematical model so to speak, it's just a principle. Mathematically, the first law can be described as the following.
$$\text{If}\quad\sum \vec F=0\quad\text{then}\quad\frac{\text{d}\vec v}{\text{d}t}=0$$
and conversely
$$\text{If}\quad\sum \vec F\neq 0\quad\text{then}\quad\frac{\text{d}\vec v}{\text{d}t}\neq 0$$
and conversely
That's not quite correct. The logical equivalent of the first expression is
[itex]{\rm If}\quad \frac{{d\vec v}}{{dt}} \ne 0\quad {\rm then}\quad \sum {\vec F \ne 0}[/itex]
What's wrong with that? If there is acceleration there must be a net force.
There is nothing wrong with that. It is just not equivalent with your second expression.
What I was saying is that if the sum of all forces is zero, then acceleration is zero, and conversely, if the sum of all forces is not zero, then acceleration is not zero.
Yes, and it's crucial that you mention that all your vectors refer to an inertial reference frame. The logic is that in Newtonian (as well as in special relativistic) physics there exist inertial reference frames and by definition (!) in this frames a free body moves uniformly (i.e., with constant velocity). This is the content of Newton's Lex I.
Then there's a definition of force in Newtonian physics which is the time derivative of momentum (which of course needs the introduction of mass beyond the kinematical quantities). This is Newton's Lex II.
Likes Bestfrog
Only if the third law is considered too. I already mentioned that the first and second law alone work quite well in non-inertial systems.
That wouldn't exclude fictious forces. The full definition of force consists of all three laws of motion.
You quote an interesting point : Newton stated this shape of the force as a postulate. We are then driven to wonder if there could be a more mathematical explanation to it. Actually this is all the purpose of Lagrange's work (Mécanique analytique) which is marvelously explained in the Landau & Lifchitz "Mechanics". To be very straight forward they explain that the force is the derivative of the momentum (impulsion) with respect to time. As far as the momentum is [itex]\vec P = m \vec v[/itex], and the mass [itex]m[/itex] is a constant, we shall have [itex]\vec F = m \vec a[/itex]. But please read the Landau & Lifchitz for more complete informations.
Likes fedecolo
Please allow me to get forward, as I feel that your thought is in the right direction.
Newton is a great compilator, but he was an hawful guy. All people around him detested him. He finished his life away of every one, stuck by alchemy and horoscopes, far from science. The famous [itex]1/r^2[/itex] gravitation law has been stated by Robert Hook, referencing the works of Huygens on the sling physics, in a letter to Newton. This last insulted him, saying that he was a freak and did not deserve any attention. But this made the reputation of Newton, the thief, in the "Principia", until us.
A particular experience is the debate with Emilie Du Chatelet about the kinetic energy, and this is a point close to your concerns. Emily shew experimentally that it is [itex]mv^2[/itex] and not [itex]m v[/itex] as Newton postulated (once again, postulate, postulate). Emily was right, Newton was wrong.
In the XIXth century, Lagrange entered in the same mood as yours. He felt that all these postulates should be explanable by the mathematics, in a way or an other. He wrote one of the most important piece of science of the humanity in "Mécanique Analytique", and bound everything and every one (Hyugens, Hook, Newton, Du Chatelet, ...) however by including the Maupertuis's postulate of least action. You heard of Hamilton, of course, but know trom now that this is only a rewrite of Lagrange's work in a particular mathematical way.
I really insist on this : read Lev Landau and Evgueny Lifchitz, Mechanics, Ed. Mir, Moscow. If you need to understand what the classical physics is, you will find no better way. All I told you here is mathematically stated in an elegant mathematical way by these authors.
Your questioning is at the door of the understanding, please get on.
Likes fedecolo
Of course, the 3rd law is implicit in the space-time model of Newtonian and special relativistic physics. That's why I didn't mention it. What you call "fictitious forces" (which I call "inertial forces") are no forces in the sense of interactions. You get the from bringing terms from the kinematics in non-inertial reference frames to the other side of the equation. That's all.
In general relativity the concept of the intertial frames become local, and you cannot distinguish gravity from inertial forces as far as local laws are concerned, but that's another topic.
  • #31
Thank you very much, I'm going to read this book immediately!
  • #32
Eh, you've got a few misconceptions there. First, Newton didn't claim that kinetic energy itself was given by ##mv##; in fact, there was no distinction between kinetic energy and momentum during that time. It was Gottfried Leibniz who, as early as 1686, suggested that kinetic energy (which he called vis viva, or "living force") was proportional to the square of velocity. However, this view was widely contested by followers of Newton and DesCartes as it did not seem to be compatible with conservation of momentum, while ##mv## was (again there was no distinction between KE and momentum at the time).
It wasn't until 1719 and 1722 when Giovanni Poleni and Williem 's Gravesande independently confirmed Leibniz's quadratic relationship, empirically, by dropping balls onto clay. Williem 's Gravesande then told Emilie about his findings, who repeated the experiment, confirmed it, then published the results.
Likes fedecolo
FAQ: Mathematical model of Newton's first law
1. What is Newton's first law?
Newton's first law, also known as the law of inertia, states that an object at rest will remain at rest and an object in motion will continue in motion at a constant velocity, unless acted upon by an external force.
2. How is Newton's first law represented in a mathematical model?
In a mathematical model, Newton's first law is represented by the equation F=ma, where F is the net force acting on the object, m is the mass of the object, and a is the acceleration of the object.
3. What is the significance of Newton's first law in physics?
Newton's first law is significant because it provides the foundation for understanding the behavior of objects in motion. It explains why objects continue to move in a straight line at a constant speed and how external forces can change an object's motion.
4. Can Newton's first law be applied to everyday situations?
Yes, Newton's first law can be applied to everyday situations. For example, when a car suddenly stops, the passengers inside will continue to move forward due to their inertia until they are stopped by the seatbelt or airbag.
5. Are there any limitations to Newton's first law?
Newton's first law is limited to objects moving at constant velocities in a straight line. It does not account for objects that are accelerating or changing direction, which require the application of additional laws such as Newton's second law and third law.
