roger
- 318
What is the mathematicians modern rigorous definition of number ?
thanks
Roger
thanks
Roger
What type of number? A natural number? An integer? A quotient? A real number? A complex number? A hyper-real number? A hyper-complex number? A trans-finite number? A surreal number?...roger said:What is the mathematicians modern rigorous definition of number ?
thanks
Roger
hello3719 said:Apparently it seems that a number is defined as being an element of some defined set.
It is quite funny that "element" and "number" mean the same thing. So in fact we can define anything we want as a number !
That definition is misleading. You end up having to twist and distort it to an unrecognizable lump after encountering various number systems. Considering just the negative integers, you then have to modify it by "also an absence of quantity" or some other interpretation. It only goes downhill from there. What quantity does sqrt(-1) measure ? Then you start to redefine quantity until the original statement is meaningless. While all quantities may be described by numbers, not all numbers represent quantities. Some are quite qualitative.roger said:is it wrong to define it as a quantity of things eg apples ?
In fact to demonstrate such a thing one of my first lectures last year for a course started off by creating a set of cutlery and using them as numbers after defining addition and multiplication on them.HallsofIvy said:No, no one said that- a "number" is an element of some specifically defined sets, not just any set! In order to be a "number system" the set must have other things associated with it- primarily operations such as addition or multiplication. Of course,mathematicians do, regularly, define such operations for all kinds of "things" so we could in a very specific way "define" anything we want as a number!
The modern rigorous definition of number is based on the concept of sets, and defines numbers as elements of sets. This definition was developed by mathematicians in the late 19th and early 20th centuries, and is the foundation of modern number theory and algebra.
Previous definitions of number, such as the natural numbers or the real numbers, were based on intuitive concepts and did not have a rigorous mathematical foundation. The modern rigorous definition is based on set theory, which provides a rigorous and consistent framework for defining numbers.
The key principles of the modern rigorous definition of number are: numbers are defined as elements of sets, sets can be manipulated using operations such as union and intersection, and numbers can be compared and ordered using set inclusion.
The modern rigorous definition can be applied to all types of numbers, including natural numbers, integers, rational numbers, real numbers, and complex numbers. Each type of number is defined as a set with specific properties and operations.
The modern rigorous definition has had a significant impact on other areas of mathematics, such as algebra, geometry, and analysis. It has allowed for a more rigorous and consistent approach to studying numbers and their properties, and has led to the development of new mathematical concepts and theories.
